- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Appropriate use-case for M4100-D12G?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I currently have a Nighthawk X6S connected to my home's cable modem to give my devices access to the Internet, but the number of wired devices has grown to a point where it makes sense for me to get a dedicated switch. I'm considering getting the M4100-D12G, but before I do I'd like to confirm that it'll support my intended setup/use-case.
The setup will be simple: The M4100 will be the "hub" for everything, meaning that the cable modem and all of my wired devices, including the Nighthawk, will be connected to it.
I know that I can configure the M4100 to be a DHCP server, but what I'm not sure about is whether the M4100 can use DHCP to get its Internet-facing IP configuration like the Nighthawk does. If it won't use DHCP to do that, can I manually configure those details to link my home to the Internet?
I hope that my question isn't too basic/obvious, but I did attempt to get an answer using online resources before submitting this question.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Appropriate use-case for M4100-D12G?
Not sure why you intend to go for a fully managed (and expensive) switch. Of course, it can be configured to do nice things like multiple VLANs, run a DHCP server for the additional VLAN based subnetworks, and last but not least some basic routing between the subnetworks.
[edit] Just realized for a 12 port GbE switch (with two shared copper/SFP ports) it isn't very expensive anymore.[/edit]
@BK07 wrote:I know that I can configure the M4100 to be a DHCP server, but what I'm not sure about is whether the M4100 can use DHCP to get its Internet-facing IP configuration like the Nighthawk does. If it won't use DHCP to do that, can I manually configure those details to link my home to the Internet?
Nope, don't try this! The switch can't become a NAT router like the X6S. Keep the X6S as your NAT router for the Internet connection. Keep the DHCP server for the LAN on the X6S.
Aside, you seem to be confused about what is a DHCP server (this is to hand-out LAN subnet IP addresses) - the X6S router does have a DHCP client to get the public IP address on it's WAN/Internet interface.
Your set-up would look like this - regardless of the switch model:
Cable Modem <-> [WAN/Internet Port] X6S <-> [one LAN port] <-> Switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, this statement "The switch can't become a NAT router like the X6S." is the confirmation I needed. Thank you.
