Orbi WiFi 7 RBE973
Reply
Connecting ISP to SFP port
DonavanV
Initiate
Hello
I am trying to set up an Fiber ISP connection to the SFP port on our switch, I am not getting an account/link LED staus on either ports. Are these auto sensing ports are do they need to be set up with the ISP static IP address?
Thanks
DV
Model: GS724T|24-port Gigabit Smart Switch
Message 1 of 3
schumaku
Guru
Re: Connecting ISP to SFP port
Fiber and SFP is and was never autonegotiating. What SFP module is provided by the ISP exactly? For 1G they often use 1.25G, for 2G they often use 2.5G - link speeds the SFP garages can't make.
Does your ISP provide plain TCP/IP wit a complete subnet? If not ..figure.
Even a L2/3 switch can't act as a NAT router, does not have an IP address on a port...
Message 2 of 3
DonavanV
Initiate
That makes complete sense- is there way to use the switch as a pass through to a SonicWall firewall since the firewall does not have an SPF port on it?
Thank you again!
DV
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1268 views
  • 2 kudos
  • 2 in conversation
Announcements
