Orbi WiFi 7 RBE973
Reply
DHCP Relay Problem
Kerberos07
Follower
DHCP Relay Problem
Hi,
I installed Netgear M7300-24XF switch as a Backbone and I established 5 VLAN connections to this switch. VLANs are running smoothly. I set DHCP Relay to  the Windows Server 2012 DHCP server.
The issue is; while acquiring IPs across the VLANs, windows PCs and mobile devices are getting IP address but Linux & Mac OS devices do not get any IP address automatically. However, I can set IPs manually on Linux & Mac OS devices.
Model: M7300-24XF (XSM7224S)|ProSAFE 24-port |10 Gigabit Stackable L2+ Managed Switch
Message 1 of 2
JohnC_V
NETGEAR Moderator
Re: DHCP Relay Problem
Hi Kerberos07,
Welcome to our community!
I suggest you to open a chat / case online on NETGEAR support so that we can take advantage of your free support. Most likely, the clients are the one requesting an IP from the DHCP server.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 737 views
  • 0 kudos
  • 2 in conversation
Announcements
