Reply
DHCP Snooping issue after 12.0.13.8 Upgrade
Arnaud_D
Hello people,
I just upgraded my M4300-52G to the last firmware version and as soon as the switches rebooted none of my devices were able to get an ip from my dhcp servers. Until I turned off DHCP Snooping.
I checked my conf, but Trust Mode was correctly enabled on the Lag that goes to my dhcp servers's switch (and the 4 ports within the LAG).
It was working perfectly before the upgrade and I did no change to my conf, so for me the issue comes from the new firmware
DHCP SERVERS<==>SWITCH (LAG 1)<=========>(LAG 3) M4300-52G
                                   No dhcp snooping                            DHCP Snooping On, LAG3 Trusted.
Does anyone else has/had this issue ?
Thanks for your feedback 😉
Model: GSM4352S|M4300-52G - Stackable Managed Switch with 48x1G and 4x10G including 2x10GBASE-T and 2xSFP+ Layer 3
Message 1 of 2
Arnaud_D
Re: DHCP Snooping issue after 12.0.13.8 Upgrade
Hello,
Nobody else has this issue since the upgrade ?
I don't have a spare M4300 to do tests to confirm it's caused by the new firmware
Thx for your time 🙂
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 113 views
  • 0 kudos
  • 1 in conversation
Announcements
