Orbi WiFi 7 RBE973
Reply
Factory Reset button location M4250
themurf47
I have started using the M4250 series ov A/V switches. I have one that is not behaving as expected and after considerable time with tech support it was decided to performa factory reset. I could not stay on the phone with the tech for the procedure. When I got back to the project I can't, for the life of me, find a reset button on the device anywhere. The manual only gives a reset procedure if you can log into the device which I can't since that is the problem. I have looked for a picture of the device where it shows the lights and connections with descriptions but can't find that either. Anyone here know where I need to look? Thanks in advance.
Message 1 of 4
Guru
Re: Factory Reset button location M4250
Netgear has set up a community forum specifically for the LAN Switch products. Most of the people who watch that forum are more likely to have experience with LAN Switch (FS,GS and M Series) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Smart-Plus-and-Smart-Pro-Managed/bd-p/business-smart-plus-click-swi...
Thank you.
Message 2 of 4
Guru
Any progress on this?
Message 3 of 4
schumaku
Guru
Curious which exact M4250 model we're facing here.
  • most (if not all from wally brain, but I can be wrong) have a dual-purpose factory reset button
  • all have a serial port and/or a USB-C based serial port
  • all have an OOB Ethernet port (OOB port: Computer on the 192.168.0.0/24 IP address, enter http://192.168.0.239 on a browser)
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 7663 views
  • 0 kudos
  • 3 in conversation
Announcements
