Orbi WiFi 7 RBE973
Reply
Fans running full speed after 7.0.0.11 upgrade
JLE67
Hi,
I just bought a XS712v2 that came with firmware 6.6.3.3. I updated the firmware using the HTTP procedure as I have no PC with Windows.
From what I have seen, the new firmware 7.0.0.11 seems to be correctly installed as reported thru the Web interface but I am facing a problem then: the two fans always run full speed…
I have tried to re-apply the firmware update as well as do a factory reset without success.
Any idea to return to normal fans operations?
Model: XS712Tv2|12-Port 10-Gigabit Copper Smart Managed Pro Switch with 2 Copper/SFP+ Combo Ports
Message 1 of 3
schumaku
Guru
Re: Fans running full speed after 7.0.0.11 upgrade
Fetch the Tech Support Logs/Info and submit it with a problem report on https://my.netgear.com
THere is a thread on this subject on the correct community section (Smart-/Plus-/-Click-Switches) -> switch fans run at high speed after firmware upgrade to 7.0.0.11
Message 2 of 3
JLE67
Hi,
thx for the other thread.
Case opened allready with #41377856 but no news since tomorrow.
Added TechSupport and config files few minutes ago.
Best regards.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 901 views
  • 0 kudos
  • 2 in conversation
Announcements
