- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS108Ev3 running 2.00.08 no 1Gb connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Netgear GS108Ev3 recently only started to auto-negotiate to 100Mb full duplex. It used to do 1Gb. I've not made any recent changes and it was running 2.00.05. I upgraded to 2.00.08 and there was no change. I've also performed a factory reset, left it off overnight, tested the cables at work, and tried forcing my computer to 1Gb. I've also downgraded back 2.00.05 and tried version inbetween as well, no change. I'm using the Prosafe Plus Configuration Utility 2.3.20 and I cannot set the speed to 1Gb in there, it stops at 100Mb. Is there a bug here or has my switch decided that it is going to die early? Anyone have ideas of what to try next or is it time to warranty it?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Contacting support we determined the device was defective and I was an issued a RMA. I've recieved the replacement switch and I'm back to 1Gb auto-negotiated speeds on every port.
Thank you to all support staff that helped!
E-Rock
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS108Ev3 running 2.00.08 no 1Gb connectivity
Hi E-Rock,
Welcome to NETGEAR community!
I will give some description about port speed:
- The port LED have different behavior under different port speed. If your switch is 100Mb full duplex, only the port Left LED is green. Please check it.
- After do factory default, please open browser or Utility to access switch, check that all port speed type is Auto. We can set port speed as Auto-negotiate, and linked speed will display 1000M, cannot set 1G for port speed directly.
Look forward your reply, thanks.
NETGEAR Employee
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have verified for all 8 ports with both the link lights and by the system reporting it, that the switch will only negoiate to 100Mb. I can also verify that all speed states are set to AUTO.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi E-rock,
There is a chance that it might be going bad. Have you tried changing the port speed using the web-interface as well (manual - page 58). If this does not help, seek help from the support team.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi JohnRo,
I was able to change between 10 and 100Mb speeds but 1000Mb is not an option and setting to auto failed to negotiate to the 1000Mb speed. At this point I believe you are correct and will be contacting the support team for a replacement.
Thank you,
Eric
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi E-rock,
Kindly update the thread once you get contact with out support team. If the switch can run on 1000Mb before and you have not changed anything, uses the correct types of cables and the NIC is configured properly then this is pretty much boils down to the switch.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
E-Rock
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi E-rock,
Thank you for the update. We are glad that your issue was resolved.
Cheers,
