Orbi WiFi 7 RBE973
Reply
GS110TP won't retain VLAN membership on port 8
zazik
Hello,
I have some weird VLAN issue on GS110TP.
My setup looks like this:topology.png
Router has only one ethernet port, so WAN (VLAN 20) and LAN (untagged) traffic is going through the trunk port 7 of the switch.
From there VLAN20 extends to port 8 to communicate with ISP, the rest of the ports are for LAN.
Switch config is:pvid.png
 Everything works great with this setup.
But, once I reboot the switch, VLAN membership gets lost for port 8 (PVID config remains though):loss.png
It results in a LAN traffic leak to ISP and WAN traffic is not going out.
Runnig on th latest 5.4.2.30. Port 8 indeed can function properly untill reboot.
I tried saving the good config and restore it after boot, or even after factory defaults, nothing helps.
Seems like a firmware bug. I'd appreciate if anyone would spare 10 minutes to confirm this.
Thank you.
Message 1 of 5
Accepted Solutions
DanielZhang
NETGEAR Expert
Re: GS110TP won't retain VLAN membership on port 8
Hi Zazik,
Thanks for your reply.Smiley Happy
We found the the reason that make your port 8 lost VLAN configuration.
The "Probe" status means that port has been set to 'destination of port mirror'.
In this status, the port will recover VLAN configuration to default after reload just as you
see.
Actually port 8 has 'Probe' status will also impact your network forwarding if the purpose is not packets capture.
So I suggest you to delete port mirror configuration on port 8 just as following screenshot if you don't want to setup packet capture debugging for your GS110TP.
Then configure VLAN PVID & member on port 8 again that will not lost after reload or power cycle.
May the solution help youSmiley Happy
Thanks,
Daniel.
Message 4 of 5
All Replies
DanielZhang
NETGEAR Expert
Hi Zazik,
Welcome to NETGEAR  community!Smiley Happy
I also has a GS110TP but can't see same issue as your step.
1.  Did you have other configuration on port 7,8?
2. Could you please share you configuration about GS110TP?
Such as: LAG,VoIP.
Here is my GS110TP》
Thanks,
Daniel.
Message 2 of 5
zazik
Hi Daniel,
All factory defaults, no LAGG, no VoIP, the only things configured are the ones I posted.
One thing that might explain the behavior is this:probe.png
The question is what is that Port Type "Probe" on port 8?
And can I change it to some other port?
Thank for looking into this.
Really appreciate it.
Message 3 of 5
DanielZhang
NETGEAR Expert
Hi Zazik,
see.
Thanks,
Daniel.
Message 4 of 5
zazik
Hi Daniel,
You are right, not sure if that is actually made on purpose, but I was under impression that resetting into factory defaults, would clean that up. Well, sure enough, there was no explicit port mirroring configuation visible in the GUI, but saved configuration file indeed had this:
monitor session 1 destination interface 0/8
I had to enable mirroring on port 8 and then delete it to get it cleaned up.
Once "Probe" type gone everyhting worked as expected.
Thanks a lot for your efforts.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2409 views
  • 0 kudos
  • 2 in conversation
Announcements
