Orbi WiFi 7 RBE973
Reply
GS305E out of box operation
exige4davep
Follower
Can someone tell me if this switch will work, out-of-the-box, as a dumb switch?
It doesn't seem to.
I logged into admin page, changed password.  Ports seems to be active.
But still none of the downstream clients can get on the network.
I wanted to buy this switch to upgrade the configuration later if my application required it.
For now, I just need a switch.  Did I purchase the wrong product?
Thanks for any insights.
davep
Model: GS305E|5 Port Gigabit Ethernet Smart Managed Plus Switch
Message 1 of 2
schumaku
Guru
Re: GS305E out of box operation
Yes, it's operating as a normal switch serving one network.
Wih the link LED active on either end, the L2 is very likely operational.
Should the switch be connected to eg. a Cable Modem or another device allowing one device only one device, the other Devices won't get an IP address assigned, so no L3 traffic possible.
Message 2 of 2
Discussion stats
  • 1 reply
  • 631 views
  • 0 kudos
  • 2 in conversation
Announcements
