- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GSM5212P SNMP OID for reading Ouput Voltage and current and pethPsePortAdminEnable.X command
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello to the community,
I try to read output POE voltage and current from a GSM5212P and a also need to switch on and off a port with pethPsePortAdminEnable.X via SNMP.
I find only a limited set of value.
Is a switch limitation or maybe i do something wrong
Switch have firmware : 10.0.2.26
snmpwalk -v 2c -c private 192.168.10.253 powerEthernetMIB :
POWER-ETHERNET-MIB::pethPsePortPowerClassifications.1.3 = INTEGER: class0(1) POWER-ETHERNET-MIB::pethPsePortPowerClassifications.1.4 = INTEGER: class3(4) POWER-ETHERNET-MIB::pethPsePortPowerClassifications.1.5 = INTEGER: class0(1) POWER-ETHERNET-MIB::pethPsePortPowerClassifications.1.6 = INTEGER: class1(2) POWER-ETHERNET-MIB::pethMainPsePower.1 = Gauge32: 120000 Watts POWER-ETHERNET-MIB::pethMainPseOperStatus.1 = INTEGER: on(1) POWER-ETHERNET-MIB::pethMainPseConsumptionPower.1 = Gauge32: 15900 Watts POWER-ETHERNET-MIB::pethMainPseUsageThreshold.1 = INTEGER: 90 % POWER-ETHERNET-MIB::pethNotificationControlEnable.1 = INTEGER: true(1)
and snmpwalk -v 2c -c private 192.168.10.253 fastPathpowerEthernetMIB
NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.1 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.2 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.3 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.4 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.5 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.6 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.7 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.8 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.9 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.10 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.11 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.12 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.1 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.2 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.3 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.4 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.5 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.6 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.7 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.8 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.9 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.10 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.11 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.12 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.1 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.2 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.3 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.4 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.5 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.6 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.7 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.8 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.9 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.10 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.11 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.12 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethMainPseLegacy.1 = INTEGER: true(1)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GSM5212P SNMP OID for reading Ouput Voltage and current and pethPsePortAdminEnable.X command
Hi Seb06,
I just want to confirm. Since you are already using the latest firmware v10.0.2.26, are you also using the latest MIB v10.0.2.26? If not yet, kindly download it here, then use it. Let us know if it helps.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DaneA,
Yes I use MIB file v10.0.2.26.
Seb06
- Mark as New
- Bookmark
- Subscribe
- Permalink
I inquired your concern to the higher tier of NETGEAR Support. I will post here on this forum thread once I got a feedback.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just got a feedback from the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, according to SNMP Supported MIBS on the GSM5212P switch, the POWER-ETHERNET-MIB is a supported MIB. Within the POWER-ETHERNET-MIB, the value pethPsePortAdminEnable is present so this should work.
May we know what SNMP tool are you using?
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just want to follow-up on this. May we know what SNMP tool are you using? Let us know if you have further questions as well.
DaneA
