Orbi WiFi 7 RBE973
Reply
How to specify a VLAN to monitor in M4100-26-POE managed switch ?
abushqer
Follower
Hello,
Port mirroring, which is also known as port monitoring, selects network traffic that you can analyze with a network analyzer, such as a SwitchProbe device or other Remote Monitoring (RMON) probe.
This command configures a probe port and a monitored port for monitor session (port monitoring). Use the source interface <unit/slot/port> parameter to specify the interface to monitor. Use rx to monitor only ingress packets, or use tx to monitor only egress packets. If you do not specify an {rx | tx} option, the destination port monitors both ingress and egress packets. Use the destination interface <unit/slot/port> to specify the interface to receive the monitored traffic.
Format :
monitor session <session-id> {source interface <unit/slot/port> [{rx | tx}] | destination interface <unit/slot/port> | mode}
Mode :
Global Config
The most important point is, how can I specify the some VLAN to monitor in M4100-26-POE managed switch ?
I want to monitor  a VLAN traffic.
I hope for help.
Thank You
Model: M4100-26-PoE (FSM7226P)|ProSAFE 26-port Fully Managed L2 Switch with PoE
Message 1 of 2
JohnC_V
NETGEAR Moderator
Re: How to specify a VLAN to monitor in M4100-26-POE managed switch ?
Hi abushqer,
Welcome to our community!
In order for you to specifically monitor a VLAN, you may need to use SNMP.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 747 views
  • 0 kudos
  • 2 in conversation
Announcements
