- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
IPV4 muticast with IGMP snooping
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi ,
I have to send two IPv4 muticast feeds to two ports(3, 4) of switch. My multicast feeds are not vlan based frames. They are in 802.3 format only. I will connects port 6 to my test application running on Linux system and send the muticast join request from there. I want to use IGMP snooping to disable flooding of multicast frames on all ports and have muticast feeds forwarded to port 6 only. Is it possible that non vlan packets on port 3 and 4 get forwarded to port 6 only using IGMP snooping enabled?
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: IPV4 muticast with IGMP snooping
Hi Raman_JK,
Welcome to our community! 🙂
I inquired your case to our engineering team. I'll let you know immediately once we got an update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Configure three untagged ports into a switch local VLAN (use a spare ID not used elsewhere on the LAN), and enable the ICMP multicast handling for that VLAN.
Absolutely "normal" that the Multicast traffic can be tagged or untagged. Just for the UI config on the switch, these ports must be assigned to a VLAN ID, where you can configure the IGMP Multicast handling.
