- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Java for GSM7212 and GSM7312
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Trying to get my GSM7212 and GSM7312 device view to work.
I Have Java 1.7.0_79 installed and the switch addresses in the exception list.
OS is Windows 8.1
All I get is "You need JAVA Plugin. Get it from hear"
Can anyone tell me the correct way to get the "Device View" to work?
Thank-you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Java for GSM7212 and GSM7312
Hi dave6592,
Kindly answer the questions below:
a. Have you tried using other browsers like Chrome of Firefox?
b. Have you tried using other PCs or laptops to isolate the problem? Also, try using other PCs or laptops with older Windows OS such as Windows 7.
c. Have you tried using lower versions of the browsers such as Internet Explorer 9?
d. Have you tried using Java 7 on Internet Explorer?
Kindly try the steps below:
On Windows, fix the java security settings to allow local trust to specific applets:
1. Go to Control Panel (It would be best to switch to Category View) then locate Java.
2. Open Java then edit the following security section.
3. Make sure Java is enabled in browser and if ever its not, add an exception for the switch IP address.
4. Make sure under Advanced, your browser is enabled for Java.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've run into this problem too (I have two Netgear GS752TPS(B) switches), and would really like to solve it. I've given up on Firefox and Chrome, according to your notes, and am focused on IE since you seem to indicate that it would work better (even though I'd never use it otherwise! Isn't it EOL also?).
So just limiting the discussion to IE, my browser is enabled for Java, I've added the exception for the IP address of my switch (I added it as "https://10.0.1.67", accessing it only from within the same LAN, so another 10.0.1.x address; does that look right?). I am getting the message, "Error - click for details" and then "Application blocked. Click for details." Java is enabled, and I have version 8.0.1310.11 installed. Do I need to change security levels or something also?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It just doesn't work on windows ten and java whatever
That what I want and tried
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same problem here:
https://community.netgear.com/t5/Managed-Switches/EOL-for-Java-new-FW-for-GS724Tv4/m-p/1117228
IE Tab is for Windows only!
I do not use Windows!
And how long will it work with Windows? As long as the IE rendering engine is in Win.
Don't know if Edge uses still IE rendering.
And may be it is not for free:
Netgear should think about a solution for vanishing Java.
Rgds
AW
- Mark as New
- Bookmark
- Subscribe
- Permalink
I installed IE Tab, went through the installation steps, and it's still telling me that it's being blocked and the site I'm hitting needs to be in the exception list. I do not know how to do that here (my primary machine is a Mac, I am doing this on a Windows machine running Windows Server 2008.
I paid good money for these two switches, in part because they had these "Smart Switch" features that I felt would facilitate my extremely busy work day. I did not expect to have these parts of the application not working, or to do Netgear's troubleshooting.
I'm also quite disappointed with other features, such as the fact that on the monitoring screens, you can't click on the column headings to sort by that column, as in almost every other modern application. And particularly since that feature doesn't exist, it's doubly annoying that there isn't an "export data" function on these screens so that I can easily export the data to Excel where I ~can~ sort it the way I need to.
Frustrating. I hope that there are developers working on this stuff.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The GS752TPS(B) switch are not yet EOL. As far as I have checked with regard to the issue wherein Device View only works with Java 7 not Java 8, there is a patch build for the GS752TPS(B) switch that fixes the issue. I am not sure if this fix was included on the firmwares that were release since v5.3.0.25 because it is not listed as one of the bug fixes or enhancement. The latest firmware version for the GS752TPS(B) switch as of now is v5.3.0.31.
I suggest you to open a chat / online case with NETGEAR Support and inquire about patch build for the GS752TPS(B) switches for further assistance.
DaneA
