Orbi WiFi 7 RBE973
Reply
Jumbo frames being dropped on M5300
icotera
I enabled jumbo frames on the switch by issuing mtu 9216 command on all of the interfaces. Connectivity works - two connected hosts ping each other - unless I increase the packet size over the standard MTU size (-s 1472 -M do is the highest size that is not being dropped). I can also see on show interface ethernet that the Discarded Rx counter increases on the interfaces. What could be the issue?
Model: M5300-28G3 (GSM7328Sv2h2)|ProSAFE 24-port Managed L3 Gigabit Stackable Switch
Message 1 of 10
Retired_Member
Not applicable
Re: Jumbo frames being dropped on M5300
Hi @icotera,
Welcome to the community!
As the MTU config include L2 MTU and L3 MTU concept, not sure what's your config on the port. So could you please share your detailed config?
It's better if you can provide the tech-support file of the Switch:
How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/31439
Another question: Does the two host IP is in same subnet?
Hope it helps!
EricZ
NETGEAR employee
Message 2 of 10
icotera
Thank you very much for your response.
I tried both:
interface 1/0/6
set igmp
mtu 9216
switchport mode trunk
switchport trunk native vlan 10
switchport trunk allowed vlan 10
vlan pvid 10
ip mtu 9000
I guess it will contain a lot of sensitive info, so I very much would like to avoid this.
Yes.
Message 3 of 10
Retired_Member
Not applicable
Hi @icotera,
Could you please show the packet statistics of the port? Just follow below steps (keep two host ping each other with jumbo frame):
clear counters all
(wait about 1 minute)
show interface counters
show interface 1/0/6
show interface ethernet 1/0/6
Message 4 of 10
icotera
https://pastebin.com/7CjkH3DS
Message 5 of 10
icotera
show interface
https://pastebin.com/sSgEZ7fH
https://pastebin.com/VfspEwwS
Message 6 of 10
Retired_Member
Not applicable
Hi @icotera,
Thanks for your immediately response. I notice there is some 'Unacceptable Frame Type' pasket statistics on the ethernet port.
1. So could you please introduce your network topo?
2. Does the two host connect to the switch directly?
3. Does the two host in same VLAN?
4. And please share the command for jumbo frame ping on your host.
5. Could you please try to ping switch IP address with jumbo frame?
  1. Total Received Packets Not Forwarded........... 66
  2. 802.3x Pause Frames Received................... 0
  3. Unacceptable Frame Type........................ 66
Message 7 of 10
icotera
Yup, I saw those too.
Yes, so there isn't really any topology to introduce.
Yes.
Windows: ping IP -t -l 1700 -f
Linux: ping IP -s 1700 -M do
This works, I'm getting echo replies.
Message 8 of 10
Retired_Member
Not applicable
Hi @icotera,
I test in my side with M5300 switch. It's work success when two hosts ping each other with jumbo frame.
It's very stange.
What's firmware of your switch? Please make sure set MTU value to maximum on two ports that connect the host.
And could you please reload the switch and try again?
Message 9 of 10
icotera
It's very stange.
11.0.0.31
The MTU on all ports on the switch is 9216
Unfortunately, it didn't help.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2289 views
  • 0 kudos
  • 2 in conversation
Announcements
