Orbi WiFi 7 RBE973
Reply
LACP doesn't balance connections between links
ASKRZYNIARZ
Hello,
I have some issues with LACP and a M4300-24X24F switch:
- I set up LACP bonding between two linux/debian hosts.
- I use two 10Gb optical links per machine.
- linux hosts hash policy is layer3+4
- switch hash mode is 6 Src/Dest IP and TCP/UDP Port fields
- I test the setup with iperf (in parallel mode).
- switch firmware version is 12.0.7.13
- switch boot version is B1.0.0.11
So far, between the sender and the switch, things works as expected: connections are balanced between the two network links.
But, between the switch and the receiver, only one network link is used. I expect the switch to balance the connections between the two links, but that is not the case.
Therefore, I am stuck at 10Gb bandwith (I was expecting 20Gb).
The two relevants LAGs are lag2 and lag3: according to the management web interfaces, active ports are ok and the LAG is up:
lag2:
- admin mode enabled
- hash mode 6 Src/Dest IP and TCP/UDP Port fields
- STP mode Enable
- Static Mode Disable
- Link Trap Disable
- Configured Ports 1/0/3, 1/0/4
- Active Ports 1/0/3, 1/0/4
- LAG State Up
- Local Preference Mode Disable
lag3:
- STP mode Enable
- Link Trap Disable
- Configured Ports 1/0/5, 1/0/6
- Active Ports 1/0/5, 1/0/6
- LAG State Up
According to interfaces counters, on the sending side:
- 4234458 packets through enp97s0f0
- 3902574 packets through enp97s0f1
On the receiving side:
- 2 packets through enp24s0f0
- 8136583 packets through enp24s0f1
As you can see from netstat, iperf uses different connections:
ESTAB     0          3317368                 192.168.120.123:60222                   192.168.120.121:5001       users:(("iperf",pid=103750,fd=3))
ESTAB     0          3844440                 192.168.120.123:60226                   192.168.120.121:5001       users:(("iperf",pid=103750,fd=5))
ESTAB     0          2997360                 192.168.120.123:60224                   192.168.120.121:5001       users:(("iperf",pid=103750,fd=6))
ESTAB     0          3974760                 192.168.120.123:60220                   192.168.120.121:5001       users:(("iperf",pid=103750,fd=4))
Am I wrong to expect the connections to be balanced between enp24s0f0 and enp24s0f1 with Switch Hash mode 6?
--- please find additional technical informations below this line ---
sender interface definition:
auto bond0
iface bond0 inet static
        address 192.168.120.123
        netmask 255.255.255.0
        slaves enp97s0f0 enp97s0f1
        bond_mode 802.3ad
        bond_xmit_hash_policy layer3+4
receiver interface definition:
auto bond0
        address 192.168.120.121
        slaves enp24s0f0 enp24s0f1
        bond_mode 802.3ad
Here are the values of sender interfaces counters:
Before test:
4: enp97s0f0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 state UP mode DEFAULT group default qlen 1000
    link/ether 40:a6:b7:0b:8f:18 brd ff:ff:ff:ff:ff:ff
    RX: bytes  packets  errors  dropped overrun mcast
    438291403  6631898  0       3       0       6763
    TX: bytes  packets  errors  dropped carrier collsns
    219646627438 145080666 0       0       0       0
5: enp97s0f1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 state UP mode DEFAULT group default qlen 1000
    240457512  3634166  0       3       0       6209
    233533089838 154252127 0       0       0       0
11: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
    507559067  7680048  0       0       0       4846
    334964455166 221250750 0       5       0       0
After test:
    226057578116 149315124 0       0       0       0
    261713102  3955756  0       3       0       6209
    239441568044 158154701 0       0       0       0
    528814657  8001638  0       0       0       4846
    347283884050 229387782 0       5       0       0
Here are the values of receiver interfaces counters:
Before test:
2: enp24s0f0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 state UP mode DEFAULT group default qlen 1000
    link/ether 40:a6:b7:03:dd:24 brd ff:ff:ff:ff:ff:ff
    286408898772 189180258 0       3       0       6799
    422886324  6401287  0       0       0       0
3: enp24s0f1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 state UP mode DEFAULT group default qlen 1000
    195598904910 129201244 0       3       0       6221
    281424384  4258683  0       0       0       0
9: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
    363792080646 240292223 0       0       0       4832
    534048768  8081408  0       1       0       0
After test:
    286408898956 189180260 0       3       0       6800
    433834400  6566968  0       0       0       0
    207917656870 137337827 0       3       0       6222
    291732128  4414594  0       0       0       0
    376110832790 248428808 0       0       0       4834
    555304588  8403000  0       1       0       0
sender /proc/net/bonding/bond0:
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer3+4 (1)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
Peer Notification Delay (ms): 0
802.3ad info
LACP rate: slow
Min links: 0
Aggregator selection policy (ad_select): stable
System priority: 65535
System MAC address: 40:a6:b7:0b:8f:18
Active Aggregator Info:
        Aggregator ID: 8
        Number of ports: 2
        Actor Key: 15
        Partner Key: 770
        Partner Mac Address: 8c:3b:ad:66:7d:80
Slave Interface: enp97s0f0
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: 40:a6:b7:0b:8f:18
Slave queue ID: 0
Aggregator ID: 8
Actor Churn State: none
Partner Churn State: none
Actor Churned Count: 0
Partner Churned Count: 0
details actor lacp pdu:
    system priority: 65535
    system mac address: 40:a6:b7:0b:8f:18
    port key: 15
    port priority: 255
    port number: 1
    port state: 61
details partner lacp pdu:
    system priority: 32768
    system mac address: 8c:3b:ad:66:7d:80
    oper key: 770
    port priority: 128
    port number: 2
    port state: 61
Slave Interface: enp97s0f1
MII Status: up
Speed: 10000 Mbps
Duplex: full
Permanent HW addr: 40:a6:b7:0b:8f:19
Slave queue ID: 0
Aggregator ID: 8
    port key: 15
    port priority: 255
    port number: 2
    port state: 61
    oper key: 770
    port priority: 128
    port number: 1
    port state: 61
receiver /proc/net/bonding/bond0:
MII Status: up
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: slow
Min links: 0
System MAC address: 40:a6:b7:03:dd:24
        Aggregator ID: 5
        Number of ports: 2
        Actor Key: 15
        Partner Key: 772
Slave Interface: enp24s0f0
MII Status: up
Speed: 10000 Mbps
Duplex: full
Permanent HW addr: 40:a6:b7:03:dd:24
Slave queue ID: 0
Aggregator ID: 5
    system mac address: 40:a6:b7:03:dd:24
    port key: 15
    port priority: 255
    port number: 1
    port state: 61
    oper key: 772
    port priority: 128
    port number: 6
    port state: 61
Slave Interface: enp24s0f1
MII Status: up
Speed: 10000 Mbps
Duplex: full
Permanent HW addr: 40:a6:b7:03:dd:25
Slave queue ID: 0
Aggregator ID: 5
    port key: 15
    port priority: 255
    port number: 2
    port state: 61
    oper key: 772
    port priority: 128
    port number: 5
    port state: 61
Model: XSM4348S|M4300-24X24F - Stackable Managed Switch with 48x10G including 24x10GBASE-T and 24xSFP+ Layer 3
Message 1 of 9
LaurentMa
NETGEAR Expert
Re: LACP doesn't balance connections between links
Hi @ASKRZYNIARZ
Thank you for your message. While it is not 100% sure you can achieve 20Gbps using a LAG (it would really depend on your servers' capacity in fact), you are right, you should expect the traffic being balanced between the two legs of the LAG on the receive side too.
Thank you for the detailed info, we are gaining time in reviewing your config. I don't see anything wrong so far, can you tell us the results after these few changes:
1- Current software is 12.0.11.13, please upgrade (download section of the M4300 support page below):
https://www.netgear.com/support/product/m4300.aspx
2- Please retest with 12.0.11.13, is it the same?
3- If the same, please change the LAG settings (RECEIVE side) in the switch with hash mode 4 Src IP and Src TCP/UDP Port fields. Since we know iperf is sending with different source ports to same destination ports, retesting this way will show us if this is hashing issue, or else. What is the result?
4- If the same, please export the Tech-support file out of your switch (Maintenance\Export\HTTP File Export\tech support in the dropdown menu) and contact me by PM with a link to your tech support file. We will look into it, and search the root cause. It should be something else than the LAG/Hash causing the issue in this case.
Message 2 of 9
ASKRZYNIARZ
Hi. Thank you for your answer.
I upgraded the switch firmware to version 12.0.11.13
I still have the same problem. Switching to mode 4 (Src IP and Src TCP/UDP Port fields) didn't fix the problem either.
You will receive a link to the maintenance file shortly.
--- please find here some informations about the receiving mac addresses ---
Extracts from maintenance file:
*************** show mac-addr-table ***************
Address Entries Currently in Use............... 16
VLAN ID  MAC Address         Interface              IfIndex  Status
1        00:1E:C1:81:1A:42   1/0/25                 25       Learned
1        10:7B:44:92:74:8B   1/0/25                 25       Learned
1        40:A6:B7:03:DD:24   lag 3                  772      Learned
1        40:A6:B7:03:DD:25   lag 3                  772      Learned
1        40:A6:B7:0B:8F:18   lag 1                  770      Learned
1        40:A6:B7:0B:8F:19   lag 1                  770      Learned
1        40:A6:B7:0B:90:3C   lag 2                  771      Learned
1        40:A6:B7:0B:90:3D   lag 2                  771      Learned
1        84:A9:3E:84:4C:30   1/0/27                 27       Learned
1        84:A9:3E:84:8E:B8   1/0/26                 26       Learned
1        84:A9:3E:8A:86:01   1/0/28                 28       Learned
1        8C:3B:AD:66:7D:80   CPU Interface:  0/15/1 769      Management
1        8C:3B:AD:66:7D:83   vlan 1                 898      Management
1        AC:1F:6B:D9:94:6B   1/0/43                 43       Learned
1        AC:1F:6B:DC:52:6F   1/0/45                 45       Learned
1        AC:1F:6B:DC:52:E9   1/0/47                 47       Learned
and
*************** show lldp remote-device all ***************
LLDP Remote Device Summary
Local
Interface  RemID   Chassis ID            Port ID             System Name
1/0/1      7       40:A6:B7:0B:8F:19     40:A6:B7:0B:8F:19
1/0/2      11      40:A6:B7:0B:8F:18     40:A6:B7:0B:8F:18
1/0/3      12      40:A6:B7:0B:90:3C     40:A6:B7:0B:90:3C
1/0/4      13      40:A6:B7:0B:90:3D     40:A6:B7:0B:90:3D
1/0/5      15      40:A6:B7:03:DD:25     40:A6:B7:03:DD:25
1/0/6      14      40:A6:B7:03:DD:24     40:A6:B7:03:DD:24
1/0/7
1/0/8
If I look at my interface definition, I have:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: enp24s0f0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 state UP group default qlen 1000
3: enp24s0f1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 state UP group default qlen 1000
4: eno1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether ac:1f:6b:d9:94:6a brd ff:ff:ff:ff:ff:ff
5: eno2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether ac:1f:6b:d9:94:6b brd ff:ff:ff:ff:ff:ff
    inet 192.168.42.121/24 brd 192.168.42.255 scope global eno2
    inet6 fe80::ae1f:6bff:fed9:946b/64 scope link
9: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    inet 192.168.120.121/24 brd 192.168.120.255 scope global bond0
    inet 192.168.121.121/24 scope global bond0
    inet6 fe80::42a6:b7ff:fe03:dd24/64 scope link
enp24s0 is an Intel X710-DA2 network adapter. 40:a6:b7:03:dd:24 and 40:a6:b7:03:dd:25 are the default adapter MAC addresses before setting up bond0.
The 40:a6:b7:03:dd:25 address is discoved either from LLDP or LACPv1:
root@sls-1:/sys/class/net/bond0/bonding# tcpdump -i enp24s0f1 -e  | grep dd:25
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on enp24s0f1, link-type EN10MB (Ethernet), capture size 262144 bytes
13:31:25.860533 40:a6:b7:03:dd:25 (oui Unknown) > 01:80:c2:00:00:02 (oui Unknown), ethertype Slow Protocols (0x8809), length 124: LACPv1, length 110
13:31:57.068536 40:a6:b7:03:dd:25 (oui Unknown) > 01:80:c2:00:00:02 (oui Unknown), ethertype Slow Protocols (0x8809), length 124: LACPv1, length 110
13:32:28.268538 40:a6:b7:03:dd:25 (oui Unknown) > 01:80:c2:00:00:02 (oui Unknown), ethertype Slow Protocols (0x8809), length 124: LACPv1, length 110
13:32:59.468532 40:a6:b7:03:dd:25 (oui Unknown) > 01:80:c2:00:00:02 (oui Unknown), ethertype Slow Protocols (0x8809), length 124: LACPv1, length 110
--- some experiments ---
I did try to deactivate LLDP (I set LLDP Transmit and Receive to disable for the relevant physical interfaces).
According to the maintenance file, 40:a6:b7:03:dd:25 is no more in the LLDP table, but is still present ine the mac-addr table (affected to lag 3). I guess it is learned from the LACP frames.
That didn't fixed my issue either.
Message 3 of 9
LaurentMa
NETGEAR Expert
Thank you for the tech-support file. Let me recap what I can see in the file:
  • The two relevant LAGs in the M4300-24X24F switch are now LAG1 (1/0/1, 1/0/2)  and LAG3 (1/0/5, 1/0/6).
  • Your Sender Intel X710-DA2 has enp97s0f0 (40:a6:b7:0b:8f:18) and enp97s0f1 (40:a6:b7:0b:8f:19) under bond0  (40:a6:b7:0b:8f:18).
--> Sender enp97s0f0 (40:a6:b7:0b:8f:18) is connected to 1/0/2 and Sender enp97s0f1 (40:a6:b7:0b:8f:19) is connected to 1/0/1 both under LAG1.
  • The Receiver Intel X710-DA2 has enp24s0f0 (40:a6:b7:03:dd:24) and enp24s0f1 (40:a6:b7:03:dd:25) under bond0 (40:a6:b7:03:dd:24).
--> Receiver enp24s0f0 (40:a6:b7:03:dd:24) is connected to 1/0/6 and Receiver enp24s0f1 (40:a6:b7:03:dd:25) is connected to 1/0/5 both under LAG3.
  • According to your tests, LAG mode 6 or mode 4 doesn't change the issue on LAG3,  enp24s0f0 (40:a6:b7:03:dd:24) doesn't receive much traffic out of 1/0/6 and all the traffic is received by enp24s0f1 (40:a6:b7:03:dd:25) out of 1/0/5 from LAG3 on the receive side
@ASKRZYNIARZ, I didn't find any obvious issue in the Tech-Support file, so I am escalating it internally to the rest of the team, and we will come back to you here shortly.
Message 4 of 9
LaurentMa
NETGEAR Expert
Hi @ASKRZYNIARZ
Thank you for the tech-support file. Everything is normal in there, it means that there is no particular issue with your configuration in the switch.
Please come back to Mode 6 - Src/Dest IP and TCP/UDP Port fields for your LAG on the receive side.
On the transmit side, the hashing is OK but on the receive side, the switch is using one link only. It would indicate that the Modulo-N hash algorithm is defeated by your iperf setup. If you think about it, there are only 2 ports in the LAG, so the algorithm outputs 1 or 2 each time. Given the source and destination MAC and IP are always the same for all packets, all comes down to the 4 different TCP ports that are used by iperf on the transmit side. I believe these four ports are defeating the algorithm in this particular setup.
Could you help test with more, like 8 TCP connections?  Another test could be to change the destination TCP ports for the iPerf connections. You could start multiple iperf servers (on your same server) using different ports with the “-p” option.
Please let us know and we'll continue to help you -
Message 5 of 9
ASKRZYNIARZ
Hi,
I did the tests you suggested, and you are right about my tests defeating the hash function.
I did check all available hash functions, and every one of them were defeated in my setup.
As a default, iperf uses sucessing even number for clients ports.
By forcing odd numbers for some client ports, the connections are balanced as expected.
The main issue is that the various linux kernel I have at hand (4.19 or 5+) seem to use only even numbers for random clients ports, so I guess the connections may never balance properly if the lag is used exclusively for communications between the same two linux hosts.
I don't know if my usecase is uncommon or not, but in the later case, you should consider adding a new hash method that feeds L2 and L3 infos to a pseudorandom function (pseudorandom as defined in cryptography), and choose ports based on a modulo applied to the function returned value.
I guess that would solve any similar issues.
Message 6 of 9
ASKRZYNIARZ
edit: infos should be L3 and L4, not L2 and L3
Message 7 of 9
LaurentMa
NETGEAR Expert
Hi @ASKRZYNIARZ
Thank you very much for confirming that changing port numbers allowed for correct parsing through the algorithm / LAG legs during your test.
The change you are suggesting is a great idea, but you need to know that hashing algorithm is in the hardware (underlying switch chipset) so it can't be changed without a new hardware.
I hope that this exploration will serve you and the rest of our great Community. Networking admins need to understand the issues and apply configuration to mitigate them. This is exactly what you have done, many thanks for that.
I think iPerf testing isn't a real-world behavior,  and I believe that the Source/Destination IP and Source/Destination TCP/UDP algorithm (mode 6 in the LAG) is the most effective one for typical server installations. Having same IP sources and destinations alongside always even L4  source/destination ports is very unlikely - even with Linux in general. I believe you have spotted a typical iPerf behavior here.
Message 8 of 9
ASKRZYNIARZ
Thank you for your reply.
Could you please explain how the hashes are calculated? It would help define configurations that mitigate such issues.
Message 9 of 9
Discussion stats
  • 8 replies
  • 2535 views
  • 1 kudo
  • 2 in conversation
Announcements
