Orbi WiFi 7 RBE973
Reply
LAN to WAN Configuration
Imer
Good evening, i would like to request advices for the following problem:
one of my customer employee destroys internet bandwidth for all other workstations on a medium local lan with large uploads
the WAN link is DSL 1000kbps/18000 kbps
i suspect all
i can't access the router, nor the workstations, i can only work at the switch level.
So my question is, would a S3300 or M4300 52x help me limit lan to wan upload per ports (for exemple limit at 256 kps) and maybe monitor with wireshark with port mirroring?
thanks alot for your advices
Message 1 of 6
JohnRo
NETGEAR Employee Retired
Re: LAN to WAN Configuration
Hello Imer,
Welcome to the community!
You should be able to do this on switches with rate limiting (S3300 egress only), both of the models you have mentioned support this. Here's an example on one of our standalone smart switch. Click here. As an alternative, you can also use QoS and give it a low priority so it won't hog out the bandwidth.
Thanks,
Message 2 of 6
DaneA
@Imer,
Let us know if you have further questions.
DaneA
NETGEAR Community Team
Message 3 of 6
Imer
hi,
Thanks for the advice, i made an offer to my customer for an S3300, will let you know how it went.
Message 4 of 6
JohnRo
Hi Imer,
We'll wait for your update and see how it turns out. Feel free to post if you have additional questions.
Have a great day!
Thanks,
Message 5 of 6
JohnRo
Hi Imer,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
Message 6 of 6
Discussion stats
  • 5 replies
  • 1771 views
  • 0 kudos
  • 3 in conversation
Announcements
