- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
M4100 Auto-VoIP vlan 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Auto-VoIP factory-configured vlan 2 is causing me a major headache. I cannot, for the life of me, figure out how to turn off the Auto-VoIP feature for vlan 2. I found a method circulating for another model switch, where you visit Switching--Auto-VoIP--and change the Auto-VoIP vlan ID to another vlan that is unused. That did nothing for me on this M4100-26-POE.
How can I add the M4100-26-POE into an environment where vlan 2 is highly utilized, but not for VoIP applications? It seems to work if I use vlan2 as the management vlan, but as soon as I switch to a different vlan for switch management, it breaks everything and I can no longer add ports to vlan 2 in vlan membership.
I cannot simply reconfigure the network beyond my department, which is configured with several critical devices on vlan 2.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Andy,
Is your version the official latest release? The latest official version of Auto-VoIP vlan is 0, if the situation allows you to upgrade to the latest version and try again.
The latest firmware is 10.0.2.30.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Andy,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: M4100 Auto-VoIP vlan 2
Thank you for suggesting that. -and no, it's not the latest version. Time for an update. Hopefully this will align this switch more with my other newer M4100-50's. They have like you said, Auto-Voip by default to 0.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks so much for your insight. This was an immediate and direct fix to the issue that I was having.
