Orbi WiFi 7 RBE973
Reply
M4300-525 Main UI access
lillyschneider
Follower
Hallo,
The main UI interface is not accesspile, only the AV works.
I compared the configuration with a similar switch(same model, same firemware version) but found nothing.
The login via https//ip:49151 but also don't works .
Any help?
Message 1 of 3
Accepted Solutions
msi
Luminary
Luminary
Re: M4300-525 Main UI access
Do check if HTTP is disabled and if HTTPS is actually enabled using "show ip http" and if a SSL/TLS certificate is installed (or at least a self-signed certificate is present). The command should show all three information you might be looking for.
Context: This has happened to me in the past when I restored a configuration onto a replacement switch but wondered why HTTPS wasn't working afterwards only to realized quite a bit later that no certificate was present - hence the switch couldn't actually enable HTTPS (and I also had disabled plain HTTP).
Message 3 of 3
All Replies
schumaku
Guru
Use the OOB and/or the console port instead.
Message 2 of 3
msi
Luminary
Luminary
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1384 views
  • 1 kudo
  • 3 in conversation
Announcements
