- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
M4300-52G-POE+ VLAN participation needed on stack-mode ports needed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
It looks like that when ports get switched over to stack-port mode you don't need to do much else but only switch to stack mode and reboot them. However I've recently converted 2 ports that previously were uplink ports and let the VLANs defined as is. Things work but I'm uncertain whether or not VLAN participation is even needed to be defined when a Port is switched to stack mode. - No explanations that I could quickly find in the manuals thus my question here.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@msi,
I just want to follow-up on this. Let us know if you have further inquiries.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: M4300-52G-POE+ VLAN participation needed on stack-mode ports needed?
Hi @msi,
I inquired your post to the higher tier of NETGEAR Support. Here is the feedback of the higher tier of NETGEAR Support: "When the port is changed to stacking mode, it is not necessary to make any other changes to the port settings. Settings such as VLAN are not relevant when the switch port is in stacking mode."
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
@msi,
DaneA
