Orbi WiFi 7 RBE973
Reply
M4300-8X8F no connectivity with Juniper EX3300 (Juniper DAC)
NS_BL
Hello!
I have few Juniper EX3300 switches connected using Juniper DACs and now purchased M4300 for test lab cluster.
Can't get 10gbe link between EX3300 and M4300 to work - ports are always down.
I tried two native Juniper DACs.
EX-SFP-10GE-DAC-3M SFP+ 10-Gigabit Ethernet Direct Attach Copper (twinax copper cable), 3m
and
EX-SFP-10GE-DAC-5M SFP+ 10-Gigabit Ethernet Direct Attach Copper (twinax copper cable), 5m
else, I have some old Cisco DACs used to connect M4300 and servers NICs - it's working fine until I try to use it to connect switches.
also, I'd tried to connect this Juniper DAC to M4300 ports 1/0/1 and 1/0/3  and it's came up!
so, I suppose there is some software related problem, but can't find the clue.
any help will be appricated!
Message 1 of 3
atian
Re: M4300-8X8F no connectivity with Juniper EX3300 (Juniper DAC)
Hi, could you dump the eeprom on Juniper's DCC cable using the following command?
show fiber-port optics-info all
show fiber-port optics all
show fiber-port optics-eeprom all.
Message 2 of 3
NS_BL
(M4300-8X8F) #show fiber-ports optics-info all
                         Link Link                                 Nominal
                       Length Length                                   Bit
                         50um 62.5um                                  Rate
Port     Vendor Name      [m] [m]  Serial Number    Part Number     [Mbps] Rev  Compliance
1/0/1    Amphenol         0   0    APF13360028MY0   584990002        10300 A    DAC
1/0/2    CISCO-TYCO       0   0    TED1552BVNJ      1-2053783-2      10300 P    DAC
1/0/4    CISCO-TYCO       0   0    TED1546BA54      1-2053783-2      10300 P    DAC
1/0/5    CISCO-TYCO       0   0    TED1546BA7K      1-2053783-2      10300 P    DAC
1/0/6    CISCO-MOLEX      0   0    MOC154401QU      74752-9520       10300 08   DAC
1/0/7    CISCO-TYCO       0   0    TED1546BA1S      1-2053783-2      10300 P    DAC
1/0/8    CISCO-TYCO       0   0    TED1552BVQC      1-2053783-2      10300 P    DAC
(M4300-8X8F) #
(M4300-8X8F) #show fiber-ports optics all
                                    Output    Input
Port      Temp  Voltage  Current     Power    Power   TX     LOS  Fault
           [C]   [Volt]     [mA]     [dBm]    [dBm]   Fault       Status
1/0/1      N/A      N/A      N/A       N/A      N/A   N/A    N/A  Remote Fault
1/0/2      N/A      N/A      N/A       N/A      N/A   N/A    N/A  No Fault
1/0/4      N/A      N/A      N/A       N/A      N/A   N/A    N/A  No Fault
1/0/5      N/A      N/A      N/A       N/A      N/A   N/A    N/A  No Fault
1/0/6      N/A      N/A      N/A       N/A      N/A   N/A    N/A  No Fault
1/0/7      N/A      N/A      N/A       N/A      N/A   N/A    N/A  No Fault
1/0/8      N/A      N/A      N/A       N/A      N/A   N/A    N/A  No Fault
(M4300-8X8F) #
(M4300-8X8F) #show fiber-ports optics-eeprom all
Port 1/0/1
vendor_name = Amphenol
vendor_sn   = APF13360028MY0
date_code   = 130905
vendor_pn   = 584990002
vendor_rev  = A
eeprom data =
03 04 21 00 00 00 00 00 04 00 00 00 67 00 00 00     ..!.........g...
00 00 03 00 41 6d 70 68 65 6e 6f 6c 20 20 20 20     ....Amphenol
20 20 20 20 00 41 50 48 35 38 34 39 39 30 30 30         .APH58499000
32 20 20 20 20 20 20 20 41 20 20 20 01 00 00 fa     2       A   ....
00 00 00 00 41 50 46 31 33 33 36 30 30 32 38 4d     ....APF13360028M
59 30 20 20 31 33 30 39 30 35 20 20 00 00 00 f6     Y0  130905  ....
37 34 30 2d 30 33 30 30 37 37 20 52 45 56 20 30     740-030077 REV 0
31 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20     1
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff     ................
Port 1/0/2
vendor_name = CISCO-TYCO
vendor_sn   = TED1552BVNJ
date_code   = 1512210
vendor_pn   = 1-2053783-2
vendor_rev  = P
eeprom data =
00 00 03 00 43 49 53 43 4f 2d 54 59 43 4f 20 20     ....CISCO-TYCO
20 20 20 20 00 00 40 20 31 2d 32 30 35 33 37 38         ..@ 1-205378
33 2d 32 20 20 20 20 20 50 20 20 20 01 00 00 0d     3-2     P   ....
00 00 00 00 54 45 44 31 35 35 32 42 56 4e 4a 20     ....TED1552BVNJ
20 20 20 20 31 35 31 32 32 31 30 30 00 00 00 06         15122100....
81 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00     ................
00 00 00 00 00 00 00 00 00 00 00 00 74 04 3b 5b     ............t.;[
43 4f 50 51 41 41 36 4a 41 42 33 37 2d 30 39 36     COPQAA6JAB37-096
31 2d 30 33 56 30 33 20 01 00 46 00 00 00 00 cf     1-03V03 ..F.....
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00     ................
53 46 50 2d 48 31 30 47 42 2d 43 55 33 4d 20 20     SFP-H10GB-CU3M
20 20 20 20 30 38 00 00 00 00 00 00 00 00 00 b5         08..........
Port 1/0/4
vendor_sn   = TED1546BA54
date_code   = 1511090
vendor_rev  = P
eeprom data =
00 00 00 00 54 45 44 31 35 34 36 42 41 35 34 20     ....TED1546BA54
20 20 20 20 31 35 31 31 30 39 30 30 00 00 00 ca         15110900....
Port 1/0/5
vendor_sn   = TED1546BA7K
date_code   = 1511090
vendor_rev  = P
eeprom data =
00 00 00 00 54 45 44 31 35 34 36 42 41 37 4b 20     ....TED1546BA7K
20 20 20 20 31 35 31 31 30 39 30 30 00 00 00 e3         15110900....
Port 1/0/6
vendor_name = CISCO-MOLEX
vendor_sn   = MOC154401QU
date_code   = 111031
vendor_pn   = 74752-9520
vendor_rev  = 08
eeprom data =
00 00 03 00 43 49 53 43 4f 2d 4d 4f 4c 45 58 20     ....CISCO-MOLEX
20 20 20 20 00 00 09 3a 37 34 37 35 32 2d 39 35         ...:74752-95
32 30 20 20 20 20 20 20 30 38 20 20 01 00 00 0b     20      08  ....
00 00 00 00 4d 4f 43 31 35 34 34 30 31 51 55 20     ....MOC154401QU
20 20 20 20 31 31 31 30 33 31 20 20 00 00 00 bb         111031  ....
Port 1/0/7
vendor_sn   = TED1546BA1S
date_code   = 1511090
vendor_rev  = P
eeprom data =
00 00 00 00 54 45 44 31 35 34 36 42 41 31 53 20     ....TED1546BA1S
20 20 20 20 31 35 31 31 30 39 30 30 00 00 00 e5         15110900....
Port 1/0/8
vendor_sn   = TED1552BVQC
date_code   = 1512210
vendor_rev  = P
eeprom data =
00 00 00 00 54 45 44 31 35 35 32 42 56 51 43 20     ....TED1552BVQC
20 20 20 20 31 35 31 32 32 31 30 30 00 00 00 02         15122100....
(M4300-8X8F) #
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2213 views
  • 0 kudos
  • 2 in conversation
Announcements
