Orbi WiFi 7 RBE973
Reply
M4300-96x with 40Gb apm402xl module Not linking with Intel XL710-Q2
mmancini
Follower
Hello,  I have an M4300-96X with a APM402Xl 40GB module in it.  I am connecting it to an intel XL710-Q2 network card using the AXLC763 direct attach cable.  I am unable to get a link between these 2 devices.  I have tried 2 different network cards in 2 different servers.  I have swapped the module to a different port as well as tried a 2nd apm module.  The switch links if I connect the switch to itself and the card links if I connect the card to itself.  But I am not able to get the card and the switch to link.  I am running Server 2019 standard on the server right now.  I have installed the latest drivers from Intel.  Any help would be appreciated.
Thanks,
Model: XSM4396K0/XSM4396K1|M4300-96X – Modular Managed Switch
Message 1 of 2
DaneA
NETGEAR Employee Retired
Re: M4300-96x with 40Gb apm402xl module Not linking with Intel XL710-Q2
@mmancini,
Welcome to the community! :cathappy:
About this, it means that the APM402XL works fine since it links when you connect the switch to itself.  The same as with the Intel XL710-Q2 which also works fine because it links if its connected to the card itself.  It is a possible compatibility issue between the APM402XL and the Intel XL710-Q2.
I suggest you to open a support ticket with the NETGEAR Support here at anytime for further investigation.  Kindly state your concern as well as you may include a link to this post.
DaneA
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 549 views
  • 0 kudos
  • 2 in conversation
Announcements
