Orbi WiFi 7 RBE973
Reply
M4300 Firmware Upgrade Path
TimJL
Tutor
Hi all,
Can I upgrade an M4300-52G-PoE+ from version 12.0.2.20 straight to 12.0.11.15 or 12.0.11.16?
I have reviewed all the release notes from 12.0.4.8 through to 12.0.11.16 and there are no noted firmware jumping limitations or requirements (eg: You must upgrade to version x before going to version y) but I wanted to check here to ensure its ok to jump from 12.0.2.20 straight to 12.0.11.16
Thanks.
T
Model: GSM4352PA|M4300-52G-PoE+ - 48x1G PoE+ Stackable Managed Switch with 2x10GBASE-T and 2xSFP+ (550W PSU)
Message 1 of 2
Accepted Solutions
Retired_Member
Not applicable
Re: M4300 Firmware Upgrade Path
Hi @TimJL
Welcome to Community!
It's ok to upgrade image from v12.0.2.20 to v12.0.11.16, but after upgrade fiwmware, please clear cache and refresh the page, due to there is some GUI menu changes. If you don't refresh the page, maybe some of the new GUI menu cannot display correctly.
Hope it helps!
Eric
Message 2 of 2
All Replies
Retired_Member
Not applicable
Hi @TimJL
Hope it helps!
Eric
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1252 views
  • 0 kudos
  • 2 in conversation
Announcements
