Orbi WiFi 7 RBE973
Reply
M4300 - Jumbo Frames
muzicman82
Hi all,
I am using a M4300 for NDI video and one of the recommendations for NDI is to disable Jumbo Frames. I do just set the frame size to 1518 for all ports? It appears that they are all set to 9198 by default... or am I looking at something else (Switching -> Ports -> Port Configuration)?
Or does this not matter if the connected device is also not configured to use jumbo frames?
Model: GSM4328S|M4300-28G - Stackable Managed Switch with 24x1G and 4x10G including 2x10GBASE-T and 2xSFP+ Layer 3
Message 1 of 2
DaneA
NETGEAR Employee Retired
Re: M4300 - Jumbo Frames
@muzicman82,
As far as I have checked the M4300 user manual here, it seems there is no option to disable Jumbo Frames.
I think it doesn't matter.  Let me share this forum thread here I found online.  One of the forum member there (mjgraves) mentioned that the important thing is knowing your bandwidth needs across each link.
DaneA
NETGEAR Community Team
Message 2 of 2
Discussion stats
  • 1 reply
  • 1846 views
  • 0 kudos
  • 2 in conversation
Announcements
