Orbi WiFi 7 RBE973
Reply
M4300 don' boot
brice76
M4300 don' boot
hello
mi switch don't boot, i think is an Erase Permanent Storage issue
how i can put an image in mi switch ?
U-Boot 2012.10-00205-gef56c5f (Jan 01 2016 - 14:02:15)VerNo=1.0.0.7
UBIFS error (pid 0): ubifs_get_sb: cannot open "ubi:fs", error -19
UBIFS error (pid 0): ubifs_mount: Error reading superblock on volume 'ubi:fs' errno=-19!
ubifsmount - mount UBIFS volume
Usage:
ubifsmount <volume-name>
- mount 'volume-name' volume
UBIFS not mounted, use ubifs mount to mount volume first!
ubifsload - load file from an UBIFS filesystem
Usage:
ubifsload <addr> <filename> [bytes]
- load file 'filename' to address 'addr'
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Saving Environment to SPI Flash...
done
Usage:
done
Usage:
ETH LINK UP: 1000FD
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Retry count exceeded; starting again
Model: GSM4328PB|M4300-28G-PoE+ - 24x1G PoE+ Stackable Managed Switch with 2x10GBASE-T and 2xSFP+ (1000W PSU)
Message 1 of 4
msi
Luminary
Luminary
Re: M4300 don' boot
In my oppinion that's definitely a case where you should reach out to Netgear and open a case on my Netgear. That switch - unless you are not the original/first owner - is covered by a lifetime warranty.
Although that could be restorable, it points into corrupted flash. IMO not worth the hassel. This can happen but its fortunately something with rare occurence that I haven't had this happen on any of our M4300 here. But that's where the lifetime warranty is for. 🙂
Message 2 of 4
brice76
Re: M4300 don' boot
nothing work on support 😞
Message 3 of 4
msi
Luminary
Luminary
Re: M4300 don' boot
Your message is to short to help you any further 😕
Didn't they react upon your request, or were you unable to open a case? You need to register the switch, then open a chat request. I've done it a couple of times and never had any issues. Please tell us what issues you are encountering.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1255 views
  • 0 kudos
  • 2 in conversation
Announcements
