Orbi WiFi 7 RBE973
Reply
M4300 lost config during upgrade
Fizzer
Our MSP upgraded one of our m4300 infrastructure switch pairs last night and in the process the config was lost (apart from the stacking configuration)
They didn't take a backup of the config before the upgrade.
I can see that we still have the old image available on the box:
Dual Image Configuration
Unit Image Name Active Image Next Active Image Image Description Version
1 image1 True True   12.0.7.12
1 image2 False False   12.0.7.10
2 image1 True True   12.0.7.12
2 image2 False False   12.0.7.10
If I set the next active image for both devices as the old image (12.0.7.10) and reboot - is it likely to contain our original config?
Otherwise I will start rebuilding the config from scratch.
Thanks in advance.
Model: XSM4324S|M4300-12X12F - Stackable Managed Switch with 24x10G including 12x10GBASE-T and 12xSFP+ Layer 3
Message 1 of 3
msi
Luminary
Luminary
Re: M4300 lost config during upgrade
I can't reliably tell you since I'm not from Netgear but I might be able to give you a "good" guess. I think the firmware image is rather a completely separate file or partition (later shows it's more likely a file) and the bootloader has a saved value on what image to load as operational code.
Unlike M4100 (only has 'dir usb'), the M4300's have a 'dir' command that can show the flash's content like this:
(m4300-12.0.7.12) #dir
         1  drwx                 3192 May 08 2019 15:01:14 .
        44  drwx                    0 Feb 01 2019 07:14:19 ..
       603  -rw-                   96 Jan 01 1970 00:01:40 snmpOprData.cfg
       924  -rw-                 6839 May 08 2019 15:01:14 running-config
        91  -rw-                  156 Jan 04 1970 13:29:22 dh512.pem
       752  -rw-             37630117 Jan 22 1970 14:21:56 image1
       753  -rw-             37710793 Jan 22 1970 14:26:16 image2
       923  -rw-                 6839 May 08 2019 15:01:09 startup-config
Total Size: 229474304
Bytes Free: 157040640
Try to check how it looks like on your stack. If the startup-config is still here it might not have been loaded properly or it might be corrupt. Unfortunately I remember that most Netgear switches would only show error such messages over the serial console during bootup but it won't end up in the log buffer.
You could try to use the copy command to get the file to a USB key or i.e. SCP it to another system.
I'd likely first try this before trying to reboot th stack into the latest or the previous firmware to see if the loading of the startup-config fails.
In contrast to the M4100's (that I have one in my lab) , it might be possible that listing the file system and copying the startup-config through ZMODEM at the boot menu might have been removed when comparing this article from Netgear about password recovery:
https://kb.netgear.com/30326/M4300-How-do-I-recover-the-password-using-the-boot-menu
Message 2 of 3
Fizzer
Thanks for the advice, in the end I rebuilt the switch config rather than hunt around for a copy on the device.
It didn't take *too* long and now we have copies of the config...!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1326 views
  • 0 kudos
  • 2 in conversation
Announcements
