Orbi WiFi 7 RBE973
Reply
M5300-52G-POE+ Does noot boot. No UBOOT - Amber solid Power - amber ports 49/50
tomtcs
Follower
M5300-52G-POE+ fails to boot after trying to perform a factory reset and erasure of the firmware to replace it with a new copy.  Now during a reboot, there's no UIBOOT sequence, no access via serial cables, no nothin.  Not sure where to start at this point.
Power light just stays amber, uplinks 49/50 solid amber as well.
Tried putting the latest .stk firmware image on a USB drive and just rebooting the switch, but that didnt' seem to do anything. Hopefully I can get this thing reloaded and back up and running so I can re-use it for my POE devices.
Model: M5300-52G-POE+ (GSM7252PSv1h2)|Prosafe 48+4 L2+ POE Stackable Managed Switch
Message 1 of 2
DaneA
NETGEAR Employee Retired
Re: M5300-52G-POE+ Does noot boot. No UBOOT - Amber solid Power - amber ports 49/50
@tomtcs,
Welcome to the community! 🙂
I suggest you to open a support ticket with NETGEAR Support here at anytime for a hardware check.  If ever your M5300-52G-POE+ is proven faulty, an online replacement will be processed for as long as its still within the hardware warranty.
DaneA
NETGEAR Community Team
Message 2 of 2
Discussion stats
  • 1 reply
  • 610 views
  • 0 kudos
  • 2 in conversation
Announcements
