Orbi WiFi 7 RBE973
Reply
Migrating from xs712Tv2 to xs712t
cadasp
I am Migrating from a  xs712T to a  xs712Tv2, is there any way possible to import the config file from the old swith to the new (import from XS712T to XS712Tv2? I'm hoping I will not have to configure this new switch from scratch.
Please Help!!!
thanks
Model: XS712T|ProSafe 12 ports smart switch with 10G fiber
Message 1 of 5
schumaku
Guru
Re: Migrating from xs712Tv2 to xs712t
Usually the answer is no. Never tried. Different hardware platforms, too.
@XavierLL - any insight?
Message 2 of 5
LaurentMa
NETGEAR Expert
Hi @schumaku: XS712T Smart Managed Pro switch and XS712Tv2 newer version make part of same family, but different platforms. Configuration file structure will be slightly different, but it should be possible to "import" most of previous configuration:
  1. Download XS712T configuration file (Maintenance\Download\HTTP File Download\Text configuration) and open it in a text editor
  2. Download XS712Tv2 configuration file (probably the default one) and open it in a text editor
  3. Compare the structure of both configuration files: although similar, some differences may appear
  4. Try to import XS712T text commands into XS712Tv2 configuration, respecting the new structure, block by block
  5. When done, save a version of XS712Tv2 new configuration file on your hard drive and upload it in XS712Tv2 for test
Hi @cadasp: Let us know how it goes!
Message 3 of 5
XavierLL
NETGEAR Employee Retired
Great description @LaurentMa
I will only add that use some tool like notepad++ will help to do the comparison between the two files 🙂
Xavier Lleixa
NETGEAR CBU PLM
Message 4 of 5
cadasp
thanks, I will give that a shot.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2542 views
  • 5 kudos
  • 4 in conversation
Announcements
