- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NETGEAR NMS300 Software
- Mark as New
- Bookmark
- Subscribe
- Permalink
A quick question if may. I have installed NMS300 on a virtual server on my local network. How do I access the NMS300 login page from a client computer?
Any advice or guidance would be appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All sorted now. The issue was the firewall on the Virtual Machine. Allowed the NMS software through and it works fine now. A simple mistake.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NETGEAR NMS300 Software
Check e.g. NMS300 User Manual, p. 18, Get Started,
Log In to the Application
To select your language and log in to the application:
1. Open a browser and connect to the application through the static IP address of the
NMS300 server.
• To connect to the application from the same NMS300 server on which you installed
the application, enter the URL http://localhost:8080.
If you entered a different port number for the NMS300 server during the application
installation, replace 8080 in this URL with the port number that you provided during
installation.
• To connect to the application from a remote computer, replace localhost with the IP
address of the NMS300 server. For example, enter http://203.0.113.56:8080, in
which 203.0.113.56 is the IP address of the NMS300 server and 8080 is the port
number for the NMS300 server.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. I'm needing to connect from a remote computer and have tried what you posted below. But sadly it does not connect and displays the following...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I can't seem to locate the manual that your referencing. Would it be possible for you to send me have the link.
- Mark as New
- Bookmark
- Subscribe
- Permalink
