Reply
Netgear M4100-26G Switch POST Problem
Marcos999
Hi everybody!
I´m opening a new discussion after discovering the reason of my issue. This is my Problem:
3. Check the Power LED on the front panel of the switch.
The LED should light in the following sequence:
• The LED turns yellow as the switch runs a power-on self-test (POST).
• If the switch passes the test, the LED turns green. The switch is working and ready to
pass data.
• If the POST fails, the Power LED blinks yellow.
Now I know why the power LED doesn´t stop blinking yellow, but i can´t find a solution in any of the official manuals. Does someone know what should I do now?
Link to the first discussion about this issue:
Install Firmware after Hard-Reset Netgear4100-26G - NETGEAR Communities
Message 1 of 2
JeraldM
NETGEAR Employee Retired
Re: Netgear M4100-26G Switch POST Problem
Hi @Marcos999,
Were you able to access the boot menu of the switch to perform a Factory Defaults? For your reference, please check this KB article.
If not, I suggest to contact support and request for a replacement, here are the steps on how to do so.
JeraldM
NETGEAR Community Team
Message 2 of 2
Discussion stats
  • 1 reply
  • 199 views
  • 0 kudos
  • 2 in conversation
Announcements
