Orbi WiFi 7 RBE973
Reply
Netgear Switch recommendation
lpasekof
I'm installing a new fiber internet connection for my business.  I need to be able to segerate data from internal and external users.  I can do that via vlans.  However, I need to be able to limit the amount of bandwidth I'm providing my external users so as to not bog down my internal/business needs.  I believe I can do this setting up bandwidth limits in QoS.  I have a couple of older Netgear FVS318G switches but the up and download limits are 100,000 kbps (100mbps) which is too low.  I need to be able to allocate around 450mbps to one vlan and the remaining 50mbps to the other.
Can you recommend a Netgear switch that will do this.
Message 1 of 2
Re: Netgear Switch recommendation
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). Not a lot of smart switch knowledge here, I suspect.
You might get better replies, and find other answers, over in the appropriate section for your device. That's probably here:
Switches - NETGEAR Communities
or
Smart / Plus / Click Switches - NETGEAR Communities
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 505 views
  • 0 kudos
  • 2 in conversation
Announcements
