Reply
No Port found error
wildcardrules
Follower
No Port found error
netgear.pngI have 2 switches, both M4300 series and both exhibiting the same behavior. Whenever I try to make any change from the Switching > Ports > Port Description web interface, I always get an error: No Port found.
I've also seen the exact same behavior while trying to modify any setting on any port from the Switching > Ports > Port Configuration page.
This is definitely a bug.
What I've done so far:
1. Rebooted the switches. No change.
2. Updated both switches to the latest firmware 12.0.11.16, no change. Problem still exists.
The only work around I've found is to enable SSH and set the port descriptions through the Enable menu via SSH. I've done this successfully. Has anyone else seen this before?
Model: GSM4352PA|M4300-52G-PoE+ - 48x1G PoE+ Stackable Managed Switch with 2x10GBASE-T and 2xSFP+ (550W PSU), XSM4324CS|M4300-24X - Stackable Managed Switch with 24x10GBASE-T
Message 1 of 2
DaneA
NETGEAR Moderator
Re: No Port found error
@wildcardrules,
Welcome to the community! 🙂
Let us try to factory reset both of your M4300 switches via the CLI and check if the same problem will occur.
DaneA
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 268 views
  • 0 kudos
  • 2 in conversation
Announcements
