Orbi WiFi 7 RBE973
Reply
Password reset - NMS300
pcf_it
Hi, I have a problem with accessing web portal of NMS300. Password I set up earlier is not working, I did not set up email either.
Is there a way to change password having access to server?
Message 1 of 4
DaneA
NETGEAR Employee Retired
Re: Password reset - NMS300
@pcf_it,
Kindly try using the "Forgot Password" feature and create a new password.
DaneA
NETGEAR Community Team
Message 2 of 4
pcf_it
It's impossible, it says that I haven't set up SMTP server.
Message 3 of 4
DaneA
@pcf_it,
Kindly try to uninstall then reinstall NMS300.  Make sure that you setup an e-mail address when you reinstall it in order to make use of the "Forgot Password" option when needed.
DaneA
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 558 views
  • 0 kudos
  • 2 in conversation
Announcements
