- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SSDP PROTOCOL (DLNA) NOT WORKING BETWEEN VLAN
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Below is the solution to the problem. In any case, the discovery is not immediate (it takes a few seconds).
Here are the commands to execute on Putty
(L3-SW1)>enable
(L3-SW1)#configure
(L3-SW1)#ip multicast
(L3-SW1)#ip igmp
(L3-SW1)#ip pim dense
(L3-SW1)(config) #interface vlan 10
(L3-SW1)(interface vlan 10) #ip igmp
(L3-SW1)(interface vlan 10) #ip pim
(L3-SW1)(interface vlan 10) #exit
(L3-SW1)(config) #interface vlan 20
(L3-SW1)(interface vlan 20) #ip igmp
(L3-SW1)(interface vlan 20) #ip pim
(L3-SW1)(interface vlan 20) #end
With gui:
-Switching
-Multicast
-Igmp Snooping (ALL ENABLE)
-Igmp Vlan Conf (Enable Vlan Ineresting)
-Multicast Router Vlan (add Vlan and Enable)
-Querier Configuration (Enable
-Querier Vlan Configuration (add ip Router VlanA+VlanB)
-Routing
-Multicast
-Glabal Configuration (Enable)
-Interface Configuration VLANS (VlanA+VlanB TTL2 "if necessary"
-IGMP (Enable)
-Routing Interface (Enable VlanA+VlanB)
-PIM Global Configuration (Enable PIM-DM)
-PIM Interface Configuration VLANS (Enable VlanA+VlanB)
---------TO MODIFY PIM-DM IN THE FUTURE, YOU MUST FIRST DEACTIVATE PIM INTERFACE CONFIGURATION----------
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SSDP PROTOCOL (DLNA) NOT WORKING BETWEEN VLAN
Start your adventure in the docs on the chapter of Multicast Routing ... further on it depends on what kind of streams you need.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, essentially DLNA was designed to run on a single broadcast domain (single subnet, signle VLAN) only.
Still, you can start trying to make UPnP SSDP - it's multicast - available, so the annoucements will become visible.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
(L3-SW1)>enable
(L3-SW1)#configure
(L3-SW1)#ip igmp
With gui:
-Switching
-Multicast
-Routing
-Multicast
-IGMP (Enable)
