- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Simple MLAG configuration on M7100-24X
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have two M7100 switches and I would like to connect a few servers onto VLAN1 reduntantly via MLAG.
I have configured LAG 23 as peer link. On both switches, there is a server (RHEL7) connected to port 17.
Port 17 belongs to LAG3 on both switches, which has been assigned to VPC1.
LAG23 is up. VPC1 seems to work. But LAG3 is down.
I can't ping any other server in VLAN1 from the bonded server.
Any help appreciated.
The bond on the server looks like this:
[root@hv3 network-scripts]# cat /proc/net/bonding/bond0
Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer2 (0)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: fast
Min links: 0
Aggregator selection policy (ad_select): stable
System priority: 65535
System MAC address: 00:25:90:f9:60:c9
Active Aggregator Info:
Aggregator ID: 3
Number of ports: 2
Actor Key: 15
Partner Key: 28
Partner Mac Address: e4:f4:c6:da:78:89
Slave Interface: eno1
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 1
Permanent HW addr: 00:25:90:f9:60:c8
Slave queue ID: 0
Aggregator ID: 3
Actor Churn State: monitoring
Partner Churn State: monitoring
Actor Churned Count: 0
Partner Churned Count: 0
details actor lacp pdu:
system priority: 65535
system mac address: 00:25:90:f9:60:c9
port key: 15
port priority: 255
port number: 1
port state: 7
details partner lacp pdu:
system priority: 32768
system mac address: e4:f4:c6:da:78:89
oper key: 28
port priority: 128
port number: 211
port state: 69
Slave Interface: eth3
MII Status: up
Speed: 10000 Mbps
Duplex: full
Permanent HW addr: 00:25:90:f9:60:c9
Slave queue ID: 0
Aggregator ID: 3
port key: 15
port priority: 255
port number: 2
port state: 7
oper key: 28
port priority: 128
port number: 17
port state: 69
Config on SW1:
!Current Configuration:
!System Description "M7100-24X - ProSafe 24-port 10G L2+ Managed Switch, 10.1.0.10, B1.0.0.5"
!System Software Version "10.1.0.10"
!System Up Time "5 days 7 hrs 36 mins 38 secs"
!Cut-through mode is configured as disabled
!Additional Packages QOS,IPv6 Management,Routing
!Current SNTP Synchronized Time: SNTP Last Attempt Status Is Not Successful
enable password 8b4659130e00a6d14ea470335b68b559d5a7a6b125844ce64740cfec5c4fc1f76eda80fede8ade8546e093
4f9140f7bb68ee766c4b39490afc0b300163adbf00 encrypted
network protocol none
vlan database
vlan 20,30,40
vlan name 20 "APP"
vlan name 30 "ovirtVLAN"
vlan name 40 "VCP"
vlan routing 1 1
exit
configure
time-range
snmptrap "public" ipaddr 192.168.3.9 snmpversion snmpv1
ip routing
username "admin" password 8b4659130e00a6d14ea470335b68b559d5a7a6b125844ce64740cfec5c4fc1f76eda80fede8a
de8546e0934f9140f7bb68ee766c4b39490afc0b300163adbf00 level 15 encrypted
line console
exit
line telnet
exit
line ssh
exit
port-channel name lag 1 fs5
port-channel name lag 2 fs6
port-channel name lag 3 hv3DB
interface 0/17
addport lag 3
exit
port-channel name lag 23 peerlink
interface 0/22
addport lag 23
exit
interface 0/23
addport lag 24
exit
snmp-server sysname "switch3.db.schimmel"
snmp-server location "iWelt"
snmp-server contact "Werner Gold"
iscsi enable
interface 0/1
vlan pvid 20
vlan participation auto 1
vlan participation include 20
exit
interface 0/2
vlan pvid 20
exit
interface 0/3
vlan pvid 20
exit
interface 0/4
vlan pvid 20
exit
interface 0/5
vlan pvid 20
exit
interface 0/6
vlan pvid 20
exit
interface 0/17
exit
interface 0/22
vlan pvid 20
exit
interface 0/23
vlan pvid 30
exit
interface 0/24
vlan pvid 40
exit
interface lag 1
description 'fs5'
port-channel load-balance 7
exit
interface lag 2
description 'fs6'
exit
interface lag 3
description 'hv3DB'
vpc 1
exit
interface lag 4
exit
interface lag 5
exit
interface lag 6
exit
interface lag 7
exit
interface lag 8
exit
interface lag 9
exit
interface lag 10
exit
interface lag 11
exit
interface lag 12
exit
interface lag 13
exit
interface lag 14
exit
interface lag 15
exit
interface lag 16
exit
interface lag 17
exit
interface lag 18
exit
interface lag 19
exit
interface lag 20
exit
interface lag 21
exit
interface lag 22
exit
interface lag 23
port-channel static
no spanning-tree port mode
vpc peer-link
exit
interface lag 24
description 'Main Trunk'
port-channel static
vlan tagging 1
exit
interface vlan 1
routing
ip address 192.168.3.72 255.255.255.0
exit
feature vpc
vpc domain 1
peer-keepalive enable
peer-keepalive destination 192.168.11.73 source 192.168.11.72
peer detection enable
exit
exit
Switch2 has an analog config with complementing IP-Addresses
