- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Stack Error with 2 GSM7328Sv1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
in our company we have two GSM7328Sv1 Switches which we want to stack. We have four AX742 modules, two for each switch. When I try to put them in a stack following happens:
The stack seems to be working, the management interface shows the second switch, I can see port statistics for every port and so on. The stacking seems to work, even the menu point stacking in the UI doesn´t show any errors or failure. But when I want to transfer a file from a device connected to switch 2 to a device connected to switch 1 [and vice versa] the data rate drops and I get "Total Receive Errors" at the stacking menu. The counter rises as long as the file is transferred.
The Firmware is the same [8.0.3.49] and I don´t know what to do now 😕
I´ve tried the following: Use only one stacking module, use another cable, switch the modules...none of this worked.
So maybe someone here knows what to do?
Thanks in advance
Simon
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Stack Error with 2 GSM7328Sv1
Have you tried to factory reset both switches then reconfigure it from scratch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Factory reset was done on both in context with the firmware update. Maybe I should try an older firmware?
Thanks for your replies! 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will try with another firmware this weekend, lets see what happends.
Thanks for your replies.
Simon
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What I forgot to mention: I have to use a 3m AXC763 CX4 cable [but I´ve got the old modules]. So I´ve tried the 3m cables with the working stack and I got errors. So, either the cable were faulty or incompabtible. I´m more and more confused about this..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Last thing I tested was the working stack with my new cables at least with one of them [3m AXC763 CX4 cable] and it gave me errors, too, but it would be a too big coincidence if all of my three cables were faulty...don´t know what to test anymore..
