Orbi WiFi 7 RBE973
Reply
Switches in the stack. There is no Agent in the Host switch.
Tomasz_FLX
Hello everyone
I have this situation.
I have two switches stacked and connected with an AGC761 cable. Unit1 is GS752 and unit2 is GS728. Switches are also connected by a pachycord on ports 1. This connection is active. Both switches work.
The problem I noticed was:
- no active link on ports where the stack cable is plugged in.
- in unit1 (master) I do not see a second switch (slave) in the stack configuration.
Is the stack really not working? The unit1 display shows ID1 and the unit2 shows: active Stack / Master and ID2.
Is the connection between the switches via a pachkord on ports 1?
How do you restore the correct stack configuration? Is a restart enough?
Thanks for the suggestion.
Greetings
Tomek
Editor: Edited for Clarity
Model: GS752TS(B)|ProSAFE 48-Port Gigabit Stackable Smart Switch with 4 SFP uplinks, AGC761|1m SFP 1G/2.5G Direct Attach Cable, GS728TS(B)|ProSAFE 24-Port Gigabit Stackable Smart Switch with 4 SFP uplinks
Message 1 of 2
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: Switches in the stack. There is no slave in the master switch.
@Tomasz_FLX,
If you want to reconnect the stack, it is recommended to reboot all switches on a stack in order for it to elect its Master. Please make sure that the ports are assigned as Stack and not Ethernet.
John
NETGEAR Community Team
Message 2 of 2
All Replies
JohnC_V
NETGEAR Moderator
@Tomasz_FLX,
John
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1380 views
  • 1 kudo
  • 2 in conversation
Announcements
