Orbi WiFi 7 RBE973
Reply
TFTP enable
so_hemanth
TFTP enable
How copy the running config from switch to TFTP server or vice versa how to push the config from tftp server to switch in CLI mode ( I am searching for commands)..?
Help me
Thank you in advance..!!
Model: GSM7224P|ProSafe 24 ports gigabit managed L2 switch with PoE
Message 1 of 3
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: TFTP enable
@so_hemanth,
Welcome to the community! 🙂
You will need to create a script of your running configuration:
(GSM7224P) # show running-config running-config.scr
Then, upload the running configuration script from the GSM7224P switch to the TFTP server:
(GSM7224P) #copy nvram: script running-config.scr tftp://<TFTP server IP address>/running-config.scr
If you want to download the running configuration script from the TFTP server to the GSM7224P switch:
(GSM7224P) #copy tftp://<TFTP server IP address>/running-config.scr nvram: script running-config.scr
For more information, kindly read the following:
Pages 269-271 of the M4100 Software Administration Manual here.
Pages 371-374 of the M4100 CLI Manual here
DaneA
NETGEAR Community Team
Message 2 of 3
All Replies
DaneA
Re: TFTP enable
@so_hemanth,
DaneA
Message 2 of 3
so_hemanth
Re: TFTP enable
Dear DaneA,
Thank you for the Suggetion.....!!
Commands are working..
With best Regards
Hemanth.S
Model: GSM7224P|ProSAFE 24-port Gigabit Managed L2 Switch with PoE
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3130 views
  • 0 kudos
  • 2 in conversation
Announcements
