- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Trunk speed link issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying ot trunk 2 switches at 1000mb. The 1st is a Cisco 3650 and the latter a Netgear M4100-50G. I can only get the link to work with both sides set to "Auto", and they only negotiate at 100mb. My WAN provider has a couple of Cisco 3560 linked to the Netgear at 1000mb configed to auto, no problems on there end. I can see that they are 1000mb in the Netgear interface.
Things I have tried:
switching adn verifying the physical layer. Check. I have tried and verified other ethernet cables.
changing the Cisco trunk interface to 1000mb manual. check
changing the Cisco trunk interface to full-duplex manual. check
changing the Cisco trunk interface to "speed auto1000"mb manual. check
When chaging the interface to manual, connection goes down, I have tried rebooting the switch when this happens.
On the Netgear side, there is no command for setting the port to 1000mb. I only have options for 10 100. So it seems that auto is the only way to negotiate 1000mb. Is there anything Im missing on the netgear side?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Trunk speed link issue
Hi @mojogar,
Welcome to the community! 🙂
If the port is set to Auto, it is set at 1000 Mbps. Kindly answer the questions below:
a. Have you tried setting other ports of the M4100-50G as tagged (T) port with the Cisco 3650 and check if the trunk link negotiates at 1000Mbps?
b. What is the current firmware version of the M4100-50G switch?
c. Do you have another NETGEAR switch? If yes, kindly try to set a trunk link with the M4100-50G switch and check if it negotiates at 1000Mbps. On the other hand, using the other NETGEAR switch you have, try to set a trunk link with the Cisco 3650 and check if the trunk link negotiates at 1000Mbps.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried other ports on the Netgear to no avail.
the firmware on the switch is 10.0.1.16
Ill try your 3rd sugestions and let you know. I do have another prosafe that does negotiate at 1000mb with the cisco but the port is a straight access and not a trunk. I will try with a trunk port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the feedback. If ever the same problem occur after trying my 3rd suggestion, I suggest you to upgrade the firmware of the M4100-50G from v10.0.1.16 to the latest v10.0.2.26 in a ladderized manner. The procedure would be, first, upgrade the firmware from v10.0.1.16 to v10.01.21. Then, upgrade the firmware from v10.01.21 to v10.0.1.27 and so on until you reach the latest v10.0.2.26. Observe if the same problem will occur.
You can download the firmware versions for the M4100-50G switch on this link.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
will do.
I tried the 3rd step with a Prosafe JSG524e and it negotiated flawlessly. I will update the firmware next and keep you posted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
