- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XSM7224 sFlow config on LAGs - internal interface number 0 out of range
- Mark as New
- Bookmark
- Subscribe
- Permalink
I only get sFlow data from a few interfaces that are not part of LAGs and I am receiving this error when trying to reconfigure sFlow on all interfaces. The below error is written 16 times when I view or try to change the sFlow interface config. This switch has an L3 license installed. Example message set below. Any ideas?
Switch info:
Model: XSM7224S - 24-Port 10G SFP+ Layer 2 Stackable Managed Switch with four 10G combo ports
Firmware version: 9.0.1.46
Serial number: 2ER43653F002E
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11608 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11590 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11588 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11586 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11584 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11582 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11580 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11578 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11576 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11574 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11572 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11570 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11568 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11566 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11564 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
<14> MAY 12 10:53:51 10.0.100.100-1 NIM[-1975454704]: encode_sFlowIndex_t(364) 11562 %% {tEmWeb} nimCheckIfNumber: internal interface number 0 out of range
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XSM7224 sFlow config on LAGs - internal interface number 0 out of range
Hi ryanclough,
Welcome to the community! 🙂
From the release notes on firmware v9.0.1.37 here, sFlow Data not being transmitted when configured on a LAG is listed as one of the bug fixes. I suggest you to try to downgrade the firmware of the XSM7224S switch from v9.0.1.46 to v9.0.1.37 then check if same problem occurs.
You can download firmware v9.0.1.37 here.
Note: Be reminded to perform a factory reset on the switch after downgrading the firmware then reconfigure it from scratch.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Retired_Member,
I just want to follow-up on this. Were you able to downgrade the firmware of the XSM7224S switch from v9.0.1.46 to v9.0.1.37 then check if same problem occurs? If yes, what is the result?
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will not be able to test this for some time becuase this switch is not redundant and is the core router for our VLANs. However I do have another one of these switches on order for a separate project and may have an opportunity to do some bench tests before deploying. Will the 7224s receive a v11 update like the rest of the fully managed switch line?
Thanks for your response and followup @DaneA!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Retired_Member,
I am not sure if the XSM7224S switch will have a v11 update. However, I believe that it is possible that a new firmware version for the XSM7224S switch might be in the works.
DaneA
