- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
advice for new netwotk project with stretched cluster
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, i need an advice to new project, i need to connect 2 datacenter distant about 500 meter.
I will create a streched cluster with microsoft s2d. So i think that 4300 12x12f would be fine for start the project.
now the questions:
1) can i create a stack with 4 switches (2 for each datacenter)?
2) i saw that this model can do pfc but not Data Center Bridging, right? PFC alone is enough for RDMA?
3) support iwarp?
4) if i create a stack with four 10Gb channels theoretically i will have a 40Gb bandwidth, but exactly how it works? use a sort of load balancing algorithm?
thanks
Andrea
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: advice for new netwotk project with stretched cluster
Hi @it_user1,
Yes. As per page 29 of the M4300 data sheet here, you can stack up to 8 M4300 switch (any combination of M4300 switch model).
Let me share you these old forum threads below as reference. Hope it helps.
3) support iwarp?
iWARP is not supported since it is not mentioned in the M4300 data sheet here as well as in the M4300 user manual here.
Let me share the old forum thread below as reference:
For more information about the M4300 switch series, kindly access and read the article below:
M4300 Managed Switch Series - Stacking Information
NETGEAR ProSAFE® M4300 Intelligent Edge Series Frequently Asked Questions
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
