Orbi WiFi 7 RBE973
Reply
buffer and throughput limiting at switches
mike1983
Follower
Hi,
I need a switch that gives me the opportunity to control (limit) the throughput and the buffer-size per each specific ip.
Any suggestions?
Thank you!!
Message 1 of 2
LaurentMa
NETGEAR Expert
Re: buffer and throughput limiting at switches
Hi mike1983
Welcome to the Community!
Any Fully Managed Switch platform will offer this possibility: ACLs (access control lists) with L2 (MAC), L3 (IP) and L4 (TCP/UDP) offer filtering and associated rate limiting at the ingress and/or the egress for each traffic pattern, including burst size. These ACL rules can be time-based (based on a schedule) and binded with physical ports, LAGs or with VLANs. This is advanced classifier-based hardware implementation for security and prioritization.
M4100 models are Fast Ethernet and Gigabit models, and M4200 is Multi-Gigabit Ethernet - all models are standalone with Static L3 routing.
ACLs can work at ingress only with M4100 and M4200 models. The M4100-D12G (GSM5212-100NES ordering SKU) would be the first solution, if no other port count requirement.
M4300 models are Gigabit and 10 Gigabit models - all models are stackable and come with full Layer 3 routing.
ACLs can work at ingress and egress with M4300 models.
I hope this helps,
Message 2 of 2
Discussion stats
  • 1 reply
  • 1791 views
  • 0 kudos
  • 2 in conversation
Announcements
