Orbi WiFi 7 RBE973
Reply
how to enable Jumbo Frames on XS748T? Can't find the setting.
gparkerCOB
I have searched and found a article on the site showing how to enable Jumbo Frames on Pro Safe switches, but the interface in the XS748T looks different than their example and I can't find where to enable Jumbo Frames on the XS748T.
Anyone know how?
Thanks!
Message 1 of 5
Accepted Solutions
Carl_z
NETGEAR Expert
Re: how to enable Jumbo Frames on XS748T? Can't find the setting.
Hi gparkerCOB
Sorry for late to back, I missed your reply.
For XS748T Jumbo Frames is enabled by default. You can just use Jumbo Frames without any configurations.
BestRegards
Carl
Message 5 of 5
All Replies
Carl_z
NETGEAR Expert
Hi gparkerCOB,
Welcome to the community!
 You can go to "Switching/Ports/Port Configuration/"  There is a value named "Maximum
Frame Size". Just set this value to max to enable Jumbo Frames.
Best Regards
Carl
Netgear Employee
Message 2 of 5
gparkerCOB
Thanks Carl! I wish ours looked that way. The image you attached is much like the knowlagebase had seen while sreaching for the answer. But our switch does not have that value to change. Is it because all the ports on the switch are 10GbE? See the image below.
Message 3 of 5
gparkerCOB
Carl,
Any ideas why our switch doesn't have that setting you talked about?
Thanks
Message 4 of 5
Carl_z
NETGEAR Expert
Hi gparkerCOB
BestRegards
Carl
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2376 views
  • 1 kudo
  • 2 in conversation
Announcements
