Reply
netgear gs724t all LEDs are lit
Orktom
Hello,
After starting all the led candle reset nothing gives what you can still do? 😞
Message 1 of 4
Guru
Re: netgear gs724t all LEDs are lit
All the led's are lit? Is it working at all?
there wasn't much to your description.
HARDWARE WARRANTY | PRODUCTS COVERED BY WARRANTY | NETGEAR
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
Orktom
so they all shine all the time unfortunately the switch does not work can not be logged in, reset to factory settings also nothing
😞 Previously did not shine as the switch started correctly
Message 3 of 4
schumaku
Guru
Head to https://my.netgear.com/ check [My Registered Products] for the warranty status. This is the hint @plemans gave before.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 223 views
  • 0 kudos
  • 3 in conversation
Announcements
