- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
netgear gs728tp vlan 1 not create by user
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello i want to create new vlan on netgear gs728tp but i cant untag or tag vlan 1 says "vlan 1 not create by user" , but i have a switch netgear gs724tp i can configure the vlan 1. so i try to set vlan 10 as substitute to vlan 1 so i can untag all port.
my set up is
port 1-18 vlan 5 PVID is 5 all untag
port 19-23 vlan 20 PVID is 20 all Untag
port 24 VLAN 10 pvid 10 "Untagged all port" is connected on the modem ISP
i want to do vlan 5 admin - with internet access
vlan 20 internal - with internet access also
but when i plug my internet cable to port 24
cannot get DHCP address or internet access
please help
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear gs728tp vlan 1 not create by user
Unclear which exact Netgear switch model (including version, firmware version in place) you are using.
Ref. the "vlan 1 not create by user": Some very old switches might have had some limitations fo the VLAN 1, on some newer switches there was an oddity: If somebody put up a PVID to a port which was not member of a (or any) VLAN, this error poped up.
@markii_0204 wrote:port 1-18 vlan 5 PVID is 5 all untag
What you have configured are three individual networks, each in it's own broadcast domain, unable to talk to each other. This is what 802.1q VLANs are made for.
Do you expect the switch doing proably many2one NAT, routing for the three networks, and DHCP for the VLANs 5 and 20?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply.
This is the exact model of my switch : GS728TP — 28-Port Gigabit Ethernet PoE+ Smart Managed Pro Switch with 4 SFP Ports (16 PoE, 8 PoE+) (192W)
Firmware Version 6.0.1.29
I want to achieve is to have internet access on both vlan i will create. eg vlan 20 and vlan 5 both have access to internet
but my problem is i cant untag the vlan 1 were the internet is connected. i have a GS724tv3 FW 5.4.2.18 , the configuration is like this.
THIS CONFIGURATION IS WORKING ON "GS724tv3 FW 5.4.2.18"
PVID PORT VLAN1 VLAN5 VLAN20 REMARKS
5 1 U U CAN ACCESS INTERNET
5 2 U U CAN ACCESS INTERNET
5 - U U CAN ACCESS INTERNET
20 19 U U CAN ACCESS INTERNET
20 20 U U CAN ACCESS INTERNET
20 21 U U CAN ACCESS INTERNET
20 22 U U CAN ACCESS INTERNET
20 23 U U CAN ACCESS INTERNET
1 24 U U U ISP "INTERNET"
IF i do this configuration obove on the GS724tv3 FW 5.4.2.18 Firmware Version 6.0.1.29
no internet on all port . this is the config if i do the same .
5 1 U NO ACCESS INTERNET
5 2 U NO ACCESS INTERNET
5 - U NO ACCESS INTERNET
20 19 U NO ACCESS INTERNET
20 20 U NO ACCESS INTERNET
20 21 U NO ACCESS INTERNET
20 22 U NO ACCESS INTERNET
20 23 U NO ACCESS INTERNET
1 24 U ISP "INTERNET"
i cant configure the vlan 1 always saying " vlan 1 was not created by user"
Please Help thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That much from my side: Multiple [U]ntagged VLAN on the same port is not an appropriate clean 802.1q configuration where each VLAN is it's own dedicated broadcast domain - what this configuration does is so called asymmetrical VLAN config, the support is optional, on truns it's an optional extension protocol. Why ever, all (?) Netgear swiches seem to allow this config in the Web UI, but not all switches are working it accordingly.
I'm trying to talk to Netgear on this subject but no success @YeZ - still no communication with the Smart Managed Pro/Plus PLMs and engineering ....
- Mark as New
- Bookmark
- Subscribe
- Permalink
any updates ?
is someone can help me to set vlan on this model that can both vlan have internet access?
1 trunk port to ISP modem then 2 vlan with internet access.
thanks
