Orbi WiFi 7 RBE973
Reply
sfp trunking
cabwav
Tutor
sfp trunking
Hello
I am new to managed switches and I would like some help with configuring two Netgear switches (GS716Tv3 and GS110TP). I am trying to configure a trunk link between these switches using two SFP modules on each switch. My goal is to configure a trunk that will allow as much traffic as possible, since there are 'heavy' users on either end of both switches.
I read the document http://www.downloads.netgear.com/files/GDC/GSM7352SV2/how_to_configure_lag.pdf and that seems pretty straightforward, but apparently I am missing something. Connecting the switches using one SFP port on each switch seems to work fine, but as soon as I connect the second SFP port on each switch with a glass fibre cable, both switches seem to enter in a loop or something.
I assigned ports g17 and g18 of the GS716Tv3 as 'trunk member' to LAG ch1, and ports g9 and g10 of the GS110TP as 'port channel' to LAG1.
What am I missing here? Can you please point out how I have to configure my switches? And secondly, am I right in assuming that a double SFP link allows more traffic than a single link?
I hope that my description above makes sense, since english is not my native language.
Thank you in advance,
cabwav
Model: GS110T|ProSafe 8 ports smart switch with fiber uplink,GS716Tv3|ProSafe 16 ports Gigabit Smart switch
Message 1 of 3
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: sfp trunking
Hi cabwav,
I think that you will need to configure STP on both switches to prevent loops. I suggest that you configure RSTP on both GS716Tv3 and GS110TP.
DaneA
NETGEAR Community Team
Message 2 of 3
All Replies
DaneA
Re: sfp trunking
Hi cabwav,
DaneA
Message 2 of 3
cabwav
Tutor
Re: sfp trunking
Hi DaneA
Awesome! That did it. The GS716 had RSTP as a default setting, but the GS110 had MSTP as a default. Thank you for your help, I never would have found this one by myself....
Kind regards,
cabwav
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5086 views
  • 2 kudos
  • 2 in conversation
Announcements
