- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Access USB and SD card slots MC327
- Mark as New
- Bookmark
- Subscribe
- Permalink
Greetings how do I access the sd card slot and the usb slot? I know where the holes are but when I put in a sd card nothing happens same with USB. Can I plug my camera into the usb ? How do you get canvas to recognize Ethernet cable? Can I play photos off the sd card? Thanks CR
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Access USB and SD card slots MC327
If you have a Meural 1 the canvas does not auto-detect changes in the SD card slot, so you will need to insert the SD card and then power off the unit and power it back on (unplug and replug the unit). Once it powers back on it will recognize the SD card and read the contents, as long as the images are in a folder named meural1 (or meural2, meural3, or meural4).
Instructions on using the SD card slot can be found at https://kb.netgear.com/000060777/Can-I-use-a-micro-SD-card-to-show-my-own-images-or-videos-on-a-Meur...
Regarding your question on plugging your camera directly into the canvas, this is not supported at tis time.
NETGEAR Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
and the microUSB slot. Can you clarify how this can be used?
Similar to the SD slot, can i connect a USB memory stick, plugged into an adapter that has a microUSB connector to plug into the Canvas? Can i use it to output power to a USB powered web/security cam (mounted on the top strut of an easle on which the Canvas is displayed)?
Other?
