- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Does the Meural Canvas II have a dual voltage adapter?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m wondering if the adapter supplied with the Meural Canvas II supports dual voltage—basically if I purchase and then move to a country that has higher voltage, will this still work? (I realize I’ll need the appropriate outlet adapter).
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Does the Meural Canvas II have a dual voltage adapter?
yes, the Meural II power adapter are dual voltage.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This question is critical to me - I need to be 100% sure a Meural Canvas 2 purchased from Amazon USA work with 230 volt power in New Zealand (appreciate the plug will need to be different).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just got a Meural Canvas 2 from the US (model no: MC327BL-100PAS) and the power adaptor only lists support for 100-120V (see picture).
This is disappointing as the advise received above from @NG_Team is not correct.
I'm going to contact Netgear support to ask if there is a power supply available that works for the Canvas 2 (as the one shipped with the unit is not rated for AU or NZ).
I hope this information helps, and be aware for the model number listed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the message and photo.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Meural is a 12 volt device - if the plug supplied is 110 volt all you need to do is buy a 230v to 12v plug/cable for $20 or so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you find a solution? I am on the same boat. I brought it to Europe and not sure what to do - I am afraid to plug it and cant find an adapter that fits the back the same - any help will be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
