Shop Meural NFT Display
Welcome to the Community Please Login
Reply
Horizontal lines on Canvas 1
prietojr
I have horizontal lines on my Canvas version 1. It is only at the very top of the screen. I looked inside to make sure the ribbon cable that goes to the LCD screen was in and did not loosen up. Everything looked ok. Has anyone experienced this and if so found a solution? I would be willing to change the LCD if I only knew which would work. IMG_0991.JPGIMG_0992.JPG
Message 1 of 2
prietojr
Re: Horizontal lines on Canvas 1
Following this. I have the exact same problem. Netgear support is useless. Would like to fix also since other than that it is fine.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 388 views
  • 0 kudos
  • 1 in conversation
Announcements
Shop Meural NFT Displays
