Shop Meural NFT Display
Welcome to the Community Please Login
Reply
How to use an SD card with Meural Canvas II
Sabra
Initiate
 We recently received our Canvas II but could not find any information on how to use an SD cart to show our images to the Canvas. Key questions are:
1. How should the SD card be formatted? Can it be formatted on MacOS?
2. How should image/movie files be named on the SD card to be recognized by the Canvas?
3. How should images be organized? For example, in folders which would appear as Playlists on the Canvas?
thanks
Model: MC321| Meural Canvas II
Message 1 of 2
Accepted Solutions
KevinJ_K
NETGEAR Employee Retired
Re: How to use an SD card with Meural Canvas II
Hello Sabra,
Thank you for the questions regarding using the SD card with the Meural.
1) Yes, it can be formatted on Mac OS. You'll have the option to format on an SD card to FAT32 and ExFAT in Mac OS.
2) The image file should read "image name.[filetype]" (for example, "italy.jpeg"), and should use only alphanumeric characters.
3) It's best to organize your playlists. If you want to use folders, that should be fine.
Kevin K., NETGEAR Meural Community Team
Message 2 of 2
All Replies
KevinJ_K
Hello Sabra,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 11976 views
  • 5 kudos
  • 2 in conversation
Announcements
Shop Meural NFT Displays
