Shop Meural NFT Display
Welcome to the Community Please Login
Reply
Meural II SD card
alolewis
Initiate
Meural II SD card
My memory is almost full so I put some images on an SD card in a folder meural1.  Formatted the SD card on my Windows PC prior to putting tghe images on the SD card. The images are jpg.  Put the SD card into the Canvas II and nothing happens. Recycled power and even unplugged the Canvas II.  Where would I find the SD card?
How do I display the images on the SD card on the canvas II.
Does the SD card act as a separate playlist, can the Canvas II rotate playlists between the images on the Canvas II memory and the SD Card?
I wish there was a detailed instruction manual available for the Canvas II.
Thanks you
Message 1 of 2
NG_Team
NETGEAR Moderator
Re: Meural II SD card
You will need to put the images on the SD card in a folder called "meural1", and the Meural canvas should pick them up and begin playing them (they will show up as a playlist called SD card in the Meural playlists).  There is an article on using the SD card that has useful information at https://kb.netgear.com/000060777/Can-I-use-a-micro-SD-card-to-show-my-own-images-or-videos-on-a-Meur... .
Meural Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3612 views
  • 4 kudos
  • 2 in conversation
Announcements
Shop Meural NFT Displays
